93 integra won't start
Old Jan 15, 2009 | 06:04 PM
muellteam's Avatar
Default 93 integra won't start
all of a sudden my 93 integra won't start, it cranks good but doesn't seem to be getting spark or fuel. every now and then it will start, but as soon as you shut it off it won't start again. I have replaced the main relay, fuel pump and fuel filter, and distributor. Any help is appreciated.
Mark
Old Jan 15, 2009 | 06:15 PM
DA9_SE's Avatar
Default Re: 93 integra won't start
Have you checked to see if you are actually getting power from the battery to the main relay so that it can send power to the fuel pump to pump fuel out of the tank? If you're not getting power, changing the main relay, fuel pump, and distributor will not work because those were not the problem. Check for power to the main relay. It could be just that or it could be that and something else.
Something similar to this happened to my 93 Integra in December.
Old Jan 15, 2009 | 09:38 PM
da9leo's Avatar
I <3 DA's
try searching here www.g2ic.com
Old Jan 16, 2009 | 06:51 AM
StokelesS_g2's Avatar
Please lock up these NooB posts.
tangiblestar
Oct 29, 2017 04:33 PM
PatrickFrantz
Jul 17, 2008 11:37 AM
uszcrx
24
Sep 9, 2006 01:05 PM
justincredble
Jun 29, 2005 11:55 AM
