99-00 civic Si (NEED HELP PLEASE) TRYING TO TROUBLE SHOOT!!!
i have a 99-00 civic si ....
its currently making a vibration on the passenger side when i make right turns....
now its when i drive period....
i thought it was the axle ... i lifted the car up and saw that the boot was torn ... so i bought a brand new axle and changed it ... its currently doing the same thing.
-what could possibly be wrong with my car????
- tires are all brand new ...
SOMEONE HELP ME TROUBLE SHOOT!!!! PLEASE BE ELABORATE WITH EXPLAINING THANKS!!!!
I LOVE HONDA-TECH
I LOVE HONDA-TECH
You could have gotten a second bad axle. I used to go through them like crazy when I had my Civic. Also try swapping your front/rear wheels. See if that helps.
definaterly jack your car up and see if there is any play in your wheel check and see if its coming from the ball joint tie rod ends, or the bushing on the control arm.if it seems to be coming from the ball joint replace very soon you dont want your whell falling off!
if there isnt any play swap your tires to make sure they are balanced.
you can hear it when im makiing turns or accellerating... hrmmm ... i dont beleive its the axle... ... how often do wheel bearings go out... and ball joints....???? HELP !!!!!
i vote wheel bearing. you can check this by making sure the wheel is off the ground and wiggle it side to side (to check the tie rod) and up and down (to check wheel bearing/ ball joints)
