will a 88-89 transmission fit 90-91
Old Jan 15, 2009 | 02:42 PM
DatatRex's Avatar
Default will a 88-89 transmission fit 90-91
like the title said does anybody know if a 88-89 crx si transmission will fit a 90-91
Old Jan 15, 2009 | 03:06 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: will a 88-89 transmission fit 90-91
yes it will. but you need to take into account whether you have an 88 or an 89+ transmission. You can tell from the input shaft of the transmission what you have. If the input shaft has 1 machined ring on the end, it is an 89, and will just swap on using the clutch you have now, or a new stock clutch.
If the transmission has no machined ring on the input shaft, then it should have 21 splines instead of 20, and you should use an '88 accord clutch disk with your stock model pressure plate and flywheel.
Old Jan 15, 2009 | 05:57 PM
DatatRex's Avatar
Its a 88 transmission and its going on my sohc zc(dont know if it matters).I am wondering if I would be better off with the 90-91 transmission? Do you know if there is going to be any operating differince between the two? Thanks for the help.
Old Jan 15, 2009 | 07:14 PM
93formula's Avatar
they work the same the only difference is the 88 has a different spline count will work fine just make sure you have the clutch for an 88.
Old Jan 15, 2009 | 08:10 PM
DatatRex's Avatar
cool, thanks for the reply.
senate33
Oct 21, 2005 07:39 AM
alpalwal
10
Dec 28, 2004 06:13 PM
sykohatch
Aug 16, 2004 08:51 PM
CrXr89Si
Jan 19, 2004 11:32 PM
lscrx
Jan 4, 2004 07:32 PM
