Fluttering Crx
Old Jan 15, 2009 | 02:38 PM
scottmog's Avatar
Default Fluttering Crx
Ive had this strange problem the entire ive owned my 1990 si crx. When i hit about 75 or 80 USUALLY i start to hear a fluttering sound coming from my cluster or my left climate vent, over in that area. that is of course inside that car...
Like i said usually when im going over 75 and am slamming on the pedal to accelerate. But if i even out at 80-85 and keep a stready speed it goes away. does anyone have any sort of idea? ><
Old Jan 15, 2009 | 04:14 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Fluttering Crx
Could be the speedo cable.
Or just something vibrating like the cluster housing.
... or maybe it's the 80mph ghost!!! 0_o
Old Jan 15, 2009 | 07:41 PM
scottmog's Avatar
any other ideas? ><
Old Jan 15, 2009 | 07:57 PM
e30FTMFW's Avatar
usually if there is shacking just under acceleration it is your CV axle...that was a prob i was just having...does it shake like that when you get on the gas all the time?
Old Jan 17, 2009 | 11:39 AM
scottmog's Avatar
1. no its not from under my car 100%
2. its mostly when im accelerating past 70 and up but if i level out and keep a steady 80 mph ot 85 then the sound stops.
Old Jan 18, 2009 | 08:38 AM
scottmog's Avatar
now for a different move.
is there anyone that lives close to anahiem/gardengrove that would offer to take a ride with me on the freeway to here it?
Old Jan 18, 2009 | 10:46 AM
e30FTMFW's Avatar
It doesn't have to be from " under " the car... these probs can shake your entire car...check axles for play/check ball joint boot for rips/and tie rob end boots...your prob is most likely suspention related my friend
Old Jan 18, 2009 | 10:49 AM
e30FTMFW's Avatar
Unless I don't get what u mean by fluttering? Is it just a noise or vibration? A vibration could be causing the noise
Old Jan 18, 2009 | 12:43 PM
scottmog's Avatar
It is JUST a noise, again sorry for not clarifying that.
Anyone can make that exact sound, just exhale and roll an R in your mouth. That is exactly how it sounds. Ill try to make vid to help.
Old Jan 18, 2009 | 12:52 PM
Targa250R's Avatar
be professional
It's probably either the speedo cable or something stuck/loose in the leftmost vent. Do you have the vent switched to the HVAC system or to fresh air?
Old Jan 18, 2009 | 02:29 PM
scottmog's Avatar
fresh air usually.
jdm_h22
May 4, 2013 02:53 PM
waspcrx19
Jun 22, 2010 09:29 AM
1gen crxer
Mar 5, 2004 05:16 PM
type_racerz
Sep 9, 2002 05:40 PM
