DC knuckles on a CRX ????
Old Jan 15, 2009 | 01:54 PM
lilbill_ed8's Avatar
Default DC knuckles on a CRX ????
i have a set of DC knuckles off a GSR.. will they work on my EF .. i have skunk upper control arms and an edt traction bar for adjustments .. i imagin this should work because i have seen people running 5 lugs on efs which comes of a DC right .. i put them on my car a while back but immediately took them off because it set the camber and toe way out of spec .. but now im thinking that the new upper control arms will help bring that in a little
any help is appreciated and i would really like to run these because 1 i already have them and 2 i need to replace my pads and rotors on my current set up and the dc ones are new pads and the rotors just need to be turned
also the DC knuckles have brand new axles on them which makes them a little more desirable
thanks for your help in advance
Old Jan 15, 2009 | 02:27 PM
fltblkEFhatch's Avatar
Default Re: DC knuckles on a CRX ????
they will work for sure, but you will need to be good with alignments.
you will sit like this
front of car
top of wheels
i have the same setup
Old Jan 15, 2009 | 03:38 PM
jdmef9mang's Avatar
i tried the samer thing on my ef it threw the alignment way out of wack. i went and got ef9 front knuckles. or you can get da it is much simpler
Old Jan 15, 2009 | 03:56 PM
Tyson's Avatar
dont use them.
Old Jan 15, 2009 | 04:00 PM
Originally Posted by Tyson
dont use them.
reasons why not???
Old Jan 15, 2009 | 04:07 PM
Tyson's Avatar
because....
EFstyle's Avatar
Originally Posted by lilbill_ed8
reasons why not???
The geometry of all the angles just dont work with our chassis... one of the worst being the insane positive camber they give you. even slammed 3 inches you'd probobly still have positive camber - not very cool
Old Jan 15, 2009 | 05:12 PM
jdmef9mang's Avatar
my car is lowered 3 inches and like he is saying i had posite camber. and i have a camber kit
Old Jan 15, 2009 | 05:25 PM
meandino's Avatar
How about the EK? Would they work?
Old Jan 16, 2009 | 04:41 AM
i was looking at the knuckles again this morning and saw that the "DC" ones dont have the little hole for the abs sensor .. so what are these off of .. DA ??? and will DA knuckles work on the ef .. or should i just stick with the si setup
Old Jan 16, 2009 | 05:46 AM
dr_latino999's Avatar
No.
DA or EF only.
To further clarify, these are the knuckles that will maintain geometry: Any 90-93 USDM Specification Integra with the following model level RS/LS/GS/GS-R; Any 1988-1991 Civic/CRX exc. Wagon with the following model level: HF/DX/LX/EX/Si.
Old Jan 16, 2009 | 07:33 AM
meandino's Avatar
That sucks. We can't have five lug then.
Old Jan 16, 2009 | 07:51 AM
CRX Toad's Avatar
Of course you can, just have to press the hub out and press 5 lug hub in. But why in the world would you limit your wheel selection for 5 lug.
Old Jan 16, 2009 | 08:13 AM
meandino's Avatar
I just like the ITR and CTR wheels.
Old Jan 16, 2009 | 08:24 AM
MeanstreakCivic's Avatar
You can do it. I have DC knuckles on my car. With the Skunk2 camber kit you will be fine.
I just read your other post and you said you thought they might be DA. Either way you can make anything work. Just as long as you get the alignment done proper you will be set.
Old Jan 19, 2009 | 05:05 AM
it will work...all you have to do is adjust the tie rods, and get a camber kit, the new style, that is the upper control arms, NOT JUST the ball joint. i have the knuckles from a dc integra on my ef with skunk2 upper control arms. it rides beautifully once you get an alignment from a shop. and stops on dime.
Old Jan 19, 2009 | 05:09 AM
i also temporarily used EG knuckles on the same car with the same camber kit and it worked just fone with an eye-balled alignment that i did in 10 minutes. so "to further clarify" yes it will work...
SlowWhite_EG
Suspension & Brakes
23
Nov 16, 2014 07:33 AM
jksmith
Oct 14, 2010 04:38 PM
blackeg
Jun 18, 2007 02:10 AM
0ptimus prime
10
Jun 18, 2005 11:47 AM
