Rear wing brake light
Old Jan 15, 2009 | 03:35 AM
gasha1's Avatar
Default Rear wing brake light
Just got a rear wing from a wrecked 99 EX Coupe and I can't get the brake light to work. It is the 16 inch LED. Is there some kind of voltage regulator that usually accompany it? I tried hooking it straight to the battery with no luck. There are only two wires which I assume is hot and ground. THX.
Old Jan 15, 2009 | 04:10 AM
P_Adams's Avatar
Default Re: Rear wing brake light
Try reversing the wires. LED's are not unidirectional.
Don't worry, you won't ruin anything
P
Old Jan 15, 2009 | 07:51 AM
gasha1's Avatar
Reversing the wires didn't work.
Old Jan 15, 2009 | 08:48 AM
P_Adams's Avatar
There shouldn't be anything special about this. Like most other "dealer installed" options, the lighted rear wing is plug & play.
Check that you've got power at the body connector that you've selected when the brake is applied. One contact s/b power, the other a ground.
Todd00
11
Apr 29, 2016 04:15 PM
munchlax
Jan 16, 2010 01:57 PM
davey5300
Feb 12, 2009 04:18 PM
1fastcavi
Mar 10, 2007 01:51 PM
elmer20
Feb 10, 2007 01:26 PM
