little help needed
just did a mpfi swap from dpfi.. car starts and runs but misses very bad.. tried swappin injectors.. firing order in a manual is different from the firing order that i had on the dual point.. when i chaged it like the manual said it wouldnt start at all.. im running out of ideas.. any help will be appreciated thanks
https://honda-tech.com/forums/showth...t=firing+order
see if thats your correct firing order first...then post back...
yea the guy who did it forgot 2 wires and he fixed that and it actually starts.. but it takes a min 2 get it to start.. so im thinkin maybe the number 1 injector idnt working.. idk.. iv been messing with this thing for 3 days
personally with as much as it sucks it is pretty quick and easy to repin a wire especially the injector...can't hurt to try - I'd just go over them all - could have a wire not connected fully or something
well we swapped the pins last night.. even tried swapping around the injector clips... its not throwing any codes, which is a good thing lol.. i think were gona start over again n make sure all the wiring is correct.. thats the only thing i can think of..
i had someone say that since the motor has been sitting for a while to just let it run and it should get better.. what do u guys think?
landscapenate10
Jul 12, 2008 05:18 PM
egluism33
May 25, 2008 06:17 PM
