2jz s2000
spend 9,000 dollars with this 2jZ swap and you can have a stock supra motor in your s2000! maybe some with some bolt ons! along with throwing the balance of the car way off. put 9,000 dollars in the S2000 and you will get a much better car.
That doesn't throw off the weight of the car as much as many people make it out to be. With that motor swapped in, the car still handles great. Add a very good aftermarket suspension and you've improved it as well. Yes the weight ratio might be altered, then again, isn't that the case if someone rides in the car with you? I mean hell, having a passenger is basically the same difference in weight, actually it's probably a bigger difference.
I don't know why people knock that motor swap. It's pretty damn neat and the motor has far more potential (number wise) than an F20C/F22C.
Anyways, contact Andre up above. He is very helpful.
why mess with all that when you can buy this 650whp monster
http://www.vadriven.com/forums/showt...ht=blkturbos2k
he is willing to let it go now for less $$$$ pm me and ill call him to get the updated price.
