Integra GSR 205whp!!!! Located in North East
Old Jan 14, 2009 | 04:48 PM
GSRkid123's Avatar
Default Integra GSR 205whp!!!! Located in North East
Selling my Acura Integra GSR. Its a really clean GSR inside and out. it has a all motor build that made 205whp at Evans-tuning. IT made 220 with 3" intake, but i just left the 2.5" secreat weapon intake, i didnt want to over do it. the engine has 16900 miles on it with all its papers. In the engine and tranny alone it has 9.7K in reciepts with internals a machine work done, everything was professionally built. the chassis has no rust and has 137xxx miles on it. i bought it from a dealer ship four years ago, the car was a theft recovery fully intacted and INSPECTED. All the VIN's match and the engine was STOCK when i purchased it. Since then i've been building this car with the people at Cisco's Performance center. The Block was sent to a machine shop on california, and the head and transmission where built locally at machine shops. This car pulls very HARD and is capable of making more power i just wanted a fast daily driver with out over doing it. This car is faster then many RSX type S and S2000's. Engine is broken in and still new, i havent raced the car or taken it to the track. Askin 8.5k!
Feel free to call me (401) 2153360
205 WHP/136 Tq. All Motor Dyno Tuned at Evans tuning
Car:
2000 front and back bumper conversion
Black housing angel eyes
immaculent cloth interior (black)
painted S2K berlina black its a jet polished black
TYPE R wing (real deal)
Head:
port and polished
angle job
Type r valves
new OEM seals
new OEM head gasket
Skunk2 stage 3 cams
Crower daul valve springs
Skunk2 Titanium retainers
Skunk2 intake manifold
STI 72mm thorttle body
AEM red Cam Gears
AEM fuel rail
AEM fuel pressure regulator
AEM fuel Gauge
Precision 440 injectors
Weapon R secret weapon air inake
Block:
GSR over bored block .5
Balanced and honed Block (fresh)
Blue Printed
Crankshaft balanced
Crankshaft knife edged
eagle H-beam rods
CP high compression pistons (12.1:1)
OEM Bearings
all new seals and rings
OEM ype r bearings
ENDYNE breather kit
ARP head bolts
ARP rod bolts
Block gaurd
Moroso oil pan
Gates Racing performance timing belt
type r oil pump (new)
type r water punp (new)
braided fuel line
Tranny:
99 GSR fresh Rebuilt
Acid dipped (clean)
New Carbon coated gears and syncros
Quaife LSD
ACT stage 2 clutch
ACT pressure plate
8lb flywheel
Suspension & Wheels
Omni Power Sport full Coilovers for Type R
Type R control arms
Enkie RS7 bronze rims 17 inches** NO CURB RASH**
Toyo proxes ZR tires
Crossed drilled and slotted Rotors
Hawk Brake pads
Other parts:
Neptune Programmed p28 Ecu - **Done by Evans-Tunings**
MSD Ignition setup
Edelbrock 255 fuel pump
Apexi WS2 catback
Rage replica TRI-Y header
Bigger Raidiator (better cooling)
2 new Denso O2 sensor
Old Jan 14, 2009 | 05:49 PM
blazedcivicr's Avatar
Default Re: Integra GSR 205whp!!!! Located in North East
clean teggy
Old Jan 15, 2009 | 12:55 PM
mark4545's Avatar
More Pics!
Old Jan 15, 2009 | 02:39 PM
GSRkid123's Avatar
i have alot of clean pictures on my computer. if you like give me your email and ill send them to you. i cant upload high quality pictures because there to large in size.
Old Jan 30, 2009 | 10:42 PM
ctking's Avatar
can you send pics to im_so_much_cooler@yahoo.com ? thanks, i appreciate it
itslogz
Sep 9, 2009 07:01 PM
GSRkid123
Northeast (Sales)
Jan 14, 2009 05:00 PM
itslogz
Southeast (Sales)
13
Sep 7, 2008 11:53 PM
TwoOneSix
Oct 23, 2006 08:42 AM
