1990 Accord EX Electrical Problems
Old Jan 14, 2009 | 03:45 PM
chiaxi2002's Avatar
Default 1990 Accord EX Electrical Problems
My accord is having some electrical problems. Here is what is wrong,
*The dash tells me the brake light is out, but it is not
*When I brake it interferes with my right turn signal (It signals, but in a weird pattern), but when I let go of the brakes it goes back to normal.
It has been cold so I think that might be part of it, but if anyone knows please post it here. THANKS!
Old Jan 15, 2009 | 02:07 PM
masterkill455's Avatar
Default Re: 1990 Accord EX Electrical Problems
replace the bulb and inspect the socket, you have some kind of short circuit or backfeed
Old Jan 15, 2009 | 05:54 PM
P_Adams's Avatar
Replace the two filement bulb on the side that's effected and look for a broken ground connection. Your brake lamp is finding a ground thru another lamp socket, thus the screwy responses.
P
Old Jan 15, 2009 | 06:29 PM
1fastvtec's Avatar
Thats funny you mentioned the brake lamp being on when the bulbs are fine. Mine does the same thing. When I had the Safety done, the Honda tech told me that if they work when you push on the pedal, then in his opinion they pass. Ill have to check my bulbs and connections also. Thank P.
Old Jan 15, 2009 | 07:19 PM
by backfeed I mean its getting a ground from another circuit causing it to short or power up things it shouldnt. on my 96 theres a ground right on the core support by the battery that was corroded and it made my blinkers flash really slow, so check that and the ground from battery negative to the block and any other grounds you can locate. they must be clean shiny bright and have a tight connection
Old Jan 16, 2009 | 09:16 AM
shadydb7's Avatar
a very common problem with this generation accord is the pigtail harness connectors to the taillights become burnt and sometimes 2 wires will touch slightly. I suggest you start off by checking the rear taillight harness connectors. You may find what i'm talking about. Good luck
Old Jan 16, 2009 | 10:10 AM
P_Adams's Avatar
After I check the wires do I have to reset anything? I know some cars have a reset switch to turn off oil change light and stuff so does a Honda accord have one?
There is no reset required
Ej6milly
May 21, 2017 08:46 AM
03 Accord Girl
Sep 1, 2007 04:47 PM
DeVus32v
Jul 31, 2006 07:40 PM
