crx doors, hood, hatch, turbo stuff, built motor [WA state]
the title isnt all i have ive got tons of stuff for sale i will post prices with items as best i can but if u see soemthing drop me a line.
engine d16a6 with z6 head (mine me)
-9.0:1 pistons
-eagle rods
-balanced and blueprinted
-poly mounts
-breather tank
-vtec head
-obd1 dizzy
-cometic head gasket
-arp headstuds
-AEM cam gear
-dsm 450cc injectors
-skunk2 IM
-LS integra TB
-act 6 puk clutch
-88 RT4wd tranny no grinds
-valve cover gasket set
Im sure theres more on the engine and tranny and i do have some extras i even have a crome pro chip that will run this motor like a champ.
$2200 OBO drop in your 4wd wagon no problem
turbo kit also works with a 4wd wagon
-tubular NSR lot mani
-t3 42/48
-2 1/2 DP
-36mm WG
-dump tube
-charge pipes
-blits BOV
-oil lines
-intercooler
-couplers
-man boost controler
-clamps
$1000 OBO this kit will clear a stock radiator but u will have to re-route the dump tube so the half size is recomended
suspension goodies
-EF adjustable front upper control arms $75
-MF factory LCA's $100
-MF toe adjusters $50
-MF rear camber kit $60
-EF front LCA's with poly bushings $40
-CRX 4wd trailing arms with disc breaks and stainless lines $300
-non PS rack mounted on crossmember with poly bushings $40
-DA front breaks with slotter rotors $50
-strut tower bars (i have the front in a pic below) $40
-stock DA springs and struts (will lift your wagon about a 1/2 inch) $40
half size with fan hoses and overflow $100
integra steering wheel with sweet *** cover.... $30
CRX wiper arms with brand new blades $20
wagovan shifter with cables $20
fuel cell mount and walbro 255 pump along with some misc lines $150
$40 each
wagon rear diffs the one on the left has a broken housing but the gears are still good in both $60 takes them
4wd wagon transfer case, shifter, inner axle, outer axles, $100
4 honda 13" steelies with good tires $40
big ol' t4 turbo rebuilt $150
I have tons of spare parts in these next pics i dont realy want to go through and name a price on everything in here so PM or just ask
I am willing to seperate the engine and tranny and the more u buy the more u save i would love to sell the turbo kit engine and tranny all together. shipping is available on most items and i can meet up or deliver the bigger stuff. If u have any questions please ask either here or PM.
-9.0:1 pistons
-eagle rods
-poly mounts
-breather tank
-vtec head
-obd1 dizzy
-arp headstuds
-AEM cam gear
-skunk2 IM
-LS integra TB
-act 6 puk clutch
-t3 42/48
-2 1/2 DP
-36mm WG
-dump tube
-charge pipes
-blits BOV
-oil lines
-intercooler
-couplers
-clamps
suspension goodies
$40 each
turbodcivic510
Feb 5, 2005 08:48 PM
bump for looking.
