Spoonsport Calipers, brake disc spec
Old Aug 6, 2002 | 09:39 AM
ahki's Avatar
Default Spoonsport Calipers, brake disc spec
Hi all, does anybody know the specification of the brake rotors (disc) (or a company who can supply me a set of brake rotors) for a Honda civic 4/100PCD? to use with the Spoon Calipers?
Thanks in advance.
Ahki
Old Aug 6, 2002 | 10:50 AM
sleepercivic's Avatar
Default Re: Spoonsport Calipers, brake disc spec (ahki)
maybee the Aem big brake upgrade rotors or a rotor like the brembo or baer ones
TERRY
Old Aug 6, 2002 | 10:57 AM
Viorent GRIP!'s Avatar
I know that it is a 11in rotor that is required so the caliper can fit. I'm guessing you're not going 5 lug. But just want a larger rotor kit to be able to run the Spoon Caliper and retain factory lug pattern correct?
try these guys FastBrakes.com
Old Aug 6, 2002 | 10:58 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Spoonsport Calipers, brake disc spec (Mr. Shin)
Fastbrakes has very nice 11" two piece rotors. I`d save yourself a few pennies and just get Wilwoods unless you are looking for JDM bonus points.
Ryan
Old Aug 6, 2002 | 11:47 AM
ahki's Avatar
Hi Guys,
Thanks for the info, I think those are the ones..
I think the Fast brake rotors will do the job.
any more info on specification welcomed.
ahki
Old Aug 6, 2002 | 01:38 PM
David@DSport's Avatar
What about the old school prelude rotor trick?
Old Aug 6, 2002 | 01:49 PM
VWkila's Avatar
Default Re: Spoonsport Calipers, brake disc spec (****@A51)
I bought the Fastbreak 11" adopter kit. Which is an EXCELLENT kit, by the way.
It came with caliper bracket adopter, all the hardware and centric ring. All you need is the caliper off of Integra(non-ITR) and brake rotors.
I used old VW Corrado rotors with 4 bolt(4x100) pattern. With the centric rings in the fastbrake kit, its a perfect fit.
cadwiese
May 8, 2006 02:13 PM
m R g S r
Aug 11, 2005 10:43 PM
slimbo
Mar 6, 2003 02:19 PM
2000GSR
May 28, 2002 05:41 PM
SuperMan19
Dec 14, 2001 08:19 PM
