94 accord h22a cylinder 4 misfire
Old Jan 13, 2009 | 05:09 PM
turboh22a1's Avatar
Default 94 accord h22a cylinder 4 misfire
Alright here we go. I have a jdm h22a eagle rods je pistons darton sleves stock head. Im running hondata s300 with 780 cc injectors. car has a code 16 fuel injection code. installed new wires 2 sets of plugs car rotor new distributer, cylinders have 150psi of compression and 1% leak down. all cylinders have spark and fuel but cylinder 4 is always damp and when i remove the plug wire theres no change but when i remove cylinders 1 through 3 the motor want to die so i know it #4. I hooked up a noid light to the cylinder and it flashes as the injector fires. timing is on..anyone have any ideas...something is weird..please hels
Old Jan 19, 2009 | 03:56 PM
SLOWPOLK's Avatar
Default Re: 94 accord h22a cylinder 4 misfire
Had a that problum and it was the rong fireing order 1-3-4-2 I beleve is right. also try changing the injector to the #1 spot and see if it does the same thing if so bad inkector.
tsjeff
Mar 17, 2022 04:25 PM
Lou845
Apr 23, 2013 10:54 PM
b17 rolla
Jan 17, 2009 03:53 PM
kmeza01
May 23, 2004 06:51 PM
