my 1989 hatch has wiring problem???please help!!
i bought a 1989 hatch and i found out there is no ecu or the plugs the???i got the obd0 plugs but iam not good at the wiring it up can some one PLEASE PLEASE help me out????????thanks
Well what are you looking to do? I can provide you with the necessary wiring schematic, but it's up to you to spend a bit soldering on new plugs.
http://www.fourthgenhatch.net/mpfi.html
Review the wiring chart, let me know if for some reason you can't understand it. And I hope you have a heated garage, it's like -30 with windchill in WI.
iam trying to find where the color's of the wires go on the plug cause there more then one of the same color on the plug???
If you can't identify it off hand, you will need to trace the wires back into the engine bay either by hand, or by checking voltages along lines.
