Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Looking to buy a 2008 FA8
Old Jan 13, 2009 | 01:05 PM
D17alltheway's Avatar
Icon5 Looking to buy a 2008 FA8
Ok so im looking to buy a 2008 nhbp Si sedan.. any issues beside the 3rd gear grind (which i think they fixed by 08) that i need to look into?
Old Jan 13, 2009 | 01:07 PM
Zeusone's Avatar
Default Re: Looking to buy a 2008 FA8
proper code is FA5. just make sure everything is in new conditon.
Old Jan 13, 2009 | 02:17 PM
FijiBlueFG2's Avatar
Road House
IIRC There were a couple of 08s early in the batch that had not had the 3rd gear problem addressed yet. Most of them should be fine though.
Old Jan 13, 2009 | 06:48 PM
is it true that only the coupes are compatible with K pro
Old Jan 13, 2009 | 06:53 PM
Kidnkorner's Avatar
There is no plug and play Hondata solution for the 06+ civic si, coupe or sedan.
If you want to run Kpro you will either have to rewire your car to 2002-2004 RSX Type S specs, intall custom gauges, lose ac and cruise, or run a dual ecu set up.
But you knew all this already because you searched out the info.
Originally Posted by D17alltheway
any issues beside the 3rd gear grind that i need to look into?
The SEARCH issue.
nb0
44
Feb 26, 2009 09:51 AM
24valvage
Jan 18, 2009 05:42 AM
dawn
Feb 21, 2008 03:53 PM
stealthhatch
25
Apr 21, 2004 01:04 PM
megatron
76
Apr 3, 2002 12:19 AM
