my number 4 spark plug
Old Jan 13, 2009 | 09:30 AM
CRX30436's Avatar
Default my number 4 spark plug
i was changeing the plugs on my car and i noticed the #4 plug was white intstead of the tan brown color like normal. what could be causing that what can i do to fix it!!
Old Jan 13, 2009 | 09:53 AM
jdmed3's Avatar
Default Re: my number 4 spark plug
more description would be nice hard to tell wat your talkin about
Old Jan 13, 2009 | 10:11 AM
DTA-Zombie's Avatar
was it a different plug or different range? Could be plug difference - could be not really sparking strong enough (due to possibly distributor or spark plug wires)
he is talking about the ceramic being all white instead of any brown or anything...
were they all replaced previously at the same time?
Old Jan 13, 2009 | 10:51 AM
raene's Avatar
White means lean. If it weren't sparking the plug would be wet and smell like gas - the culprit is an injector not flowing as much as the other injectors, most likely; if you want to rule out a spark issue, go for a short drive and shut off the key while your foot's still on the gas to prevent the car from spinning down to idle and cleaning off the injector - you want the gas to remain in the chamber as much as possible, then pull the plug and examine. If it's dark and wet it's a spark issue, if it's bone white it's a fuel issue.
Get them flow balanced, replace with another injector, maybe fix a wiring issue as that is sometimes the case when an injector is presumed faulty.
inegma29
14
Apr 16, 2008 05:28 PM
wheelmaneg6
Feb 23, 2007 10:45 AM
arielb1
Jul 24, 2004 10:24 AM
Mefain
Jun 3, 2003 10:15 AM
JDM R98
Aug 16, 2001 06:32 PM
