uh 90 tegra seats in my 90 hatchy
Old Aug 6, 2002 | 06:21 AM
HatchBox's Avatar
Skoobie no more...
Default uh 90 tegra seats in my 90 hatchy
i tried searching, cuz i would have thought it would be there but its not...do 90 tegra's seats bolt right into a 90 civic? thanks
Old Aug 6, 2002 | 07:41 AM
HatchBox's Avatar
Skoobie no more...
Default Re: uh 90 tegra seats in my 90 hatchy (xxkenyon419xx)
anyone?
Old Aug 6, 2002 | 11:13 AM
zCivic's Avatar
Yes It will work. I had to use the teg rails and only 2 bolts though. They hold in pretty well though. Use the front outer rail bolt and the inner on the back near the console. You may want to put about 3/4 inch of washers or something because they will lean inwards a little.
[Modified by zCivic, 12:17 PM 8/6/2002]
Old Aug 6, 2002 | 11:58 AM
HatchBox's Avatar
Skoobie no more...
Default Re: uh 90 tegra seats in my 90 hatchy (zCivic)
pic?
Old Aug 6, 2002 | 12:15 PM
zCivic's Avatar
I'll see what can do tonight or tomorrow. At werk right now and have to get mine running again. This suxs again.
Old Aug 6, 2002 | 12:45 PM
Urban Business
Guest
Posts: n/a
back when i had some sort of a full interrior
if you flip the drivers w/ passangers 3 of 4 mounts are relitavily close. you have to drill 3 new ones anyway, but when drivers and pass are reversed they use close to stock locations and make things much easier
[Modified by TorteX, 3:46 PM 8/6/2002]
Old Aug 6, 2002 | 12:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: uh 90 tegra seats in my 90 hatchy (TorteX)
do the seats still run on the tracks then? if u flip them?
Old Aug 6, 2002 | 02:13 PM
Urban Business
Guest
Posts: n/a
yep still run on the tracks. i has to lift the outside rear mounts w/ washers and run a bolt thru the floor but they still move
Old Aug 6, 2002 | 03:03 PM
714phil's Avatar
i used one slider from my old seat and one slider from the teg seats. 3 bolts are holding mine in.
Old Aug 6, 2002 | 03:24 PM
HatchBox's Avatar
Skoobie no more...
Default Re: uh 90 tegra seats in my 90 hatchy (STD ONEpointSIX)
can u take some pictures of how it looks? how did u take one slider from each seat?
Old Aug 7, 2002 | 05:41 PM
HatchBox's Avatar
Skoobie no more...
what if i just took the civic slider and put them on the integra seats...and the integra sliders on the civic seats..would that work? then they would just bolt right in
Old Aug 7, 2002 | 05:48 PM
goforbroke's Avatar
MEAT PATTY
I don't have integra seats in my car but I put 2000 si seats in my car and they bolted up with only three holes. But it still works and it slides freely on the rails so integra ones should work also. I bolted the back two bolts and the front left bolt.
Old Aug 7, 2002 | 08:53 PM
Giuseppe's Avatar
Default Re: uh 90 tegra seats in my 90 hatchy (goforbroke)
90 teg seats in a 90 hatch
you have to bolt the civic rails to the teg seats
the inner rails bolt right up...
the outer ones are hard
i used a 2x6 piece of wood to align the outer civic rails and
used long bolts to bolt up the entire assembly.
i bolted the rail to the wood to the metal bracket under the
seat.
just measure it out, its well worth the mod but its NOT A BOLT ON
hth..
Old Aug 8, 2002 | 02:25 AM
HatchBox's Avatar
Skoobie no more...
Default Re: uh 90 tegra seats in my 90 hatchy (Giuseppe)
is there anyway u could post a pic of your set up?
Old Aug 8, 2002 | 04:08 AM
CWBETB's Avatar
The Integra seats do fit in the 88-91 Civic with modification. I used 90 Integra seats, 94+ Integra seats might be easier to install. This mod was not easy. From the Integra you will need all parts/railing that come with the seats. You need to remove one side of the railings from the Integra seat and swap the original Civic railing to it. After you do this you must drill new holes to mount the railings. Make sure you remove the seat belt holder from the Integra seat also or the seats will not fit in your car. To make the seat look a little nicer you can add you original Civic plastic covers on the side "you will need to drill and cut". Once the seats are together you will need to put them in your car. The first thing you will notice is that you will have a 2+ inch gap in the rear of the seats. To correct this you must get some spacers "hardware stores sell them" I used 2 of them. Once the seat is seated correctly you will have to enlarge the original holes on the mounting brackets. I do not recommended redrilling your floor board since this will not be as strong as your factory. Rated 8
I wrote this a while back for http://www.4thgenerationcivic.com
Old Aug 27, 2002 | 07:16 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: uh 90 tegra seats in my 90 hatchy (CWBETB)
Which side though inner or outter? and what is this 2 inch gap you speak of?
Old Aug 27, 2002 | 10:43 PM
Giuseppe's Avatar
Default Re: uh 90 tegra seats in my 90 hatchy (h8tred)
inner rails are the inner ones. the ones that are in the middle of the car
outter rails are the outter ones the ones that are towards the outside of the car
take your 90 seats out, you will see the 2 inch gap, that has to be
accounted for with the addition of the teg seats...
Old Aug 27, 2002 | 10:56 PM
h8tred's Avatar
I meant which rail do I swap with my old seat, The inner or outter. I tried the outter rail (the one by the door, Im not a retard man), But if I do that I have no place to mount the back of the seat to. I assume the other side will be the same so I'll work it anyway I can. Maybe some pics of everything will clear things up, If I can get them in I'll take pics for all to see to end the confusion forever.
[Modified by h8tred, 2:57 AM 8/28/2002]
FREDREX
Oct 8, 2012 05:50 PM
Kaan
Apr 4, 2005 11:35 AM
PFSeg
Sep 25, 2004 08:20 AM
gstintegra92
Jan 28, 2003 08:39 AM
