89 sunroof leaks
Old Aug 6, 2002 | 06:14 AM
bjr's Avatar
bjr
Default 89 sunroof leaks
The sun roof on my friends 89 accord leaks. If the car is parked with the front end higher than the rear, when it is moved level water poures into the front seat area. The drains in the front corners of the sunroof are open and work ok, does the car have rear drains also which could be plugged? If not any does anyone have any other ideas? Thanks Brian
Old Aug 6, 2002 | 08:11 AM
YeuEmMaiMai's Avatar
Default Re: 89 sunroof leaks (bjr)
replace the rubber seal around the opening and or make repairs to the latching unit so it seals tight
Old Aug 6, 2002 | 02:22 PM
Chiovnidca's Avatar
Yes. You can clean them out from inside the trunk. They run down behind the rear wheel wells.
Turbo Dan
Jun 25, 2011 11:27 AM
sfranzo
Mar 5, 2009 05:32 AM
harveyy
Oct 18, 2006 12:54 PM
dan89crxsi
Jun 12, 2003 01:06 PM
Ronin Integra8
May 25, 2003 08:38 AM
