Quick cheap mods
Old Aug 6, 2002 | 04:58 AM
Standard's Avatar
Default Quick cheap mods
What cheap mods are there that'll give me minor boosts of HP? So far I'm thinking Intake/Chip but I don't know what else. I thought about putting really big civic type R stickers all over my car, you know, each one adds about 5 horse power, but then I decided the apalling appearance kind of outweighed the HP gain.
Old Aug 6, 2002 | 06:06 AM
slowman's Avatar
I took way too long
Default Re: Quick cheap mods (Standard)
i/h/e cams
Old Aug 6, 2002 | 06:26 AM
EF8_SiR's Avatar
Not for HP gain, but a shortshifter and stripping ur interior would make ur car faster
Old Aug 6, 2002 | 06:56 AM
keithv's Avatar
Default Re: Quick cheap mods (EF8_SiR)
gutting the interior to save weight is a free "hp" mod.
Old Aug 6, 2002 | 07:05 AM
zcivic91's Avatar
Default Re: Quick cheap mods (breaka_1_9)
JUNKYARD TURBO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
Old Aug 6, 2002 | 07:20 AM
virginia_dude's Avatar
Shortshifter doesn't do squat to make your car faster. Just make a poor driver toast his transmission quicker.
Old Aug 6, 2002 | 07:37 AM
89 CRX SI's Avatar
Default Re: Quick cheap mods (virginia_dude)
Old Aug 6, 2002 | 07:40 AM
Standard's Avatar
I have a standard hatchback so I don't have any weight as it is. But so far I'm getting the a/c unit removed since it doesn't work anyway, I'm planning on getting an AEM intake and a chip at Autothority. I just got my exhaust replaced so I don't really feel like getting that done, maybe down the road. I was thinking about getting a new tru power pulley kit from AEM, but will that really do anything for me?
Old Aug 6, 2002 | 07:46 AM
EF8_SiR's Avatar
Wouldn't a faster shift throw allow the driver to engage into gear at a higher rpm?
Also, why would a shortshifter grenade ur tranny faster? Same procedure of clutch and shift no?
Old Aug 6, 2002 | 07:50 AM
wronghand's Avatar
Added leverage of the short shifter puts more stress on the shift forks. These happen to be one of the weak points of the d-series tranny.
Old Aug 6, 2002 | 08:37 AM
EF8_SiR's Avatar
Default Re: Quick cheap mods (wronghand)
What about on a b series?
Old Aug 6, 2002 | 09:11 AM
Louie B.'s Avatar
If you have a standard, no mod is going to do SQUAT without doing an MPFI swap first!!! MPFI will make a big difference!! that little TB on the DPFI is a bottleneck!
I know, I've tried.
Old Aug 6, 2002 | 09:54 AM
Standard's Avatar
Hey, standard isn't too bad I've won every race with another civic so far except for one guy. I'm just trying to get a little bit more out of it. I was thinking about getting a supercharger but I have 150K miles and don't want to put the little guy through it.
Old Aug 6, 2002 | 10:10 AM
EF'n Fast's Avatar
Intake, header, exhaust. If it's an old car...a tune-up might help too...
Nice tires will help out too, cut down on those 60ft times.
Old Aug 6, 2002 | 10:31 AM
KEVlN's Avatar
New User
Default Re: Quick cheap mods (zcivic91)
-my friend did one for 300$.
Old Aug 6, 2002 | 11:00 AM
Short Shifter is very hard on the syncros if you are one to slam a shifter around. Its common knowleges. It effectively almost double the speed of your shifts through mechanical advantage. Thats how the Syncos get abused, and the shift forks. IF you slam it around.
[Modified by virginia_dude, 3:01 PM 8/6/2002]
Old Aug 6, 2002 | 11:04 AM
raene's Avatar
Advance your timing.
Old Aug 6, 2002 | 03:53 PM
Louie B.'s Avatar
I'm not knockin the motor, just the intake manifold. an MPFI swap consists of putting the Intake manifold, distributor, and ecu out of an Si onto your std engine.
I'm running a sts myself, and a short ram intake and exhaust made no noticable difference in performance because of the small throtle body of the std manifold. After I swapped on an MPFI mani, it was like a whole new engine.
Old Aug 6, 2002 | 04:06 PM
.nate's Avatar
Yeah? Race Me
RE: YOur question... a junkyard turbo setup can be dome for anywhere form 300-700 bucks... more if you really want to make some power. It's well worth it too.. do some research on it!
[Modified by N8, 7:07 PM 8/6/2002]
Old Aug 6, 2002 | 04:34 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Quick cheap mods (raene)
How exactly is that done? Ive heard about this helping but i dont know how to dont it. Thanks alot man.
Sean
Old Aug 6, 2002 | 05:40 PM
ViperRedCRX's Avatar
HELL YA!!!! BOOST!!!!!
Old Aug 6, 2002 | 06:06 PM
daniel89civ's Avatar
Default Re: Quick cheap mods (Zit)
first do the mpfi itll make a big difference
you need
si intake manifold ,si distributor ,si computer [pm6],and do the wiring
then do a mini me d15b2 block and a d16y8 head [pg7]ecu
info
http://www.rglobal.net/users/jgray/
check under engines
Old Aug 6, 2002 | 06:13 PM
civbeater90's Avatar
Default Re: Quick cheap mods (daniel89civ)
i agree with most of you guys mpfi swap first.
Old Aug 6, 2002 | 06:48 PM
josups's Avatar
how would i go about doing a junkyard turbo...anyone?
Old Aug 6, 2002 | 09:44 PM
Proper's Avatar
Default Re: Quick cheap mods (josups)
http://www.homemadeturbo.com
this should tell you all you need to know
