horn problem
Old Jan 12, 2009 | 12:46 PM
Honda_Cribb_GS-R's Avatar
Icon6 horn problem
ok i have a sir wheel on and followed a walk through on how to hook it up (double checked everything) after i finished with it i hit the horn and no sound i can only here the horn relay clicking so i swapped out the relay (thought it was bad) and still getting the same thing the relay clicking.....so could it be the horn??? i bench tested it and it worked....so i have no clue why it doesnt work......does anybody have a wiring diagram or know were i can get one from???
thanks
Old Jan 12, 2009 | 01:43 PM
91blackEF's Avatar
Default Re: horn problem
with my horn my car dident come with one and i went to the junk yard and pulled a horn from the same year civic the 1 wire horn. well i hooked it up and nothing i had a horn laying around from a gsr so i figured i would try it but its a 2 wire horn i matched the same color wires and grounded it to the mounting bolt and it works perfect idk why the stock one dosent but a rigged gsr horn does idk hope this helps a little
Old Jan 13, 2009 | 08:53 AM
ok sweet thanks dude!!! ill give it a try
Old Jan 13, 2009 | 08:58 AM
hpi247's Avatar
any chance you broke your clockspring? is the SRS light on?
B_Swapped93
Feb 16, 2014 06:26 PM
Str1der90
Oct 17, 2013 05:15 PM
mugen si
Aug 16, 2009 05:43 PM
stocker2shocker91
Aug 3, 2006 01:30 PM
AWDxBOOST
Mar 19, 2004 01:45 PM
