car wont start
Old Jan 12, 2009 | 12:01 PM
civicb16eg's Avatar
Default car wont start
d16y8 in a 94 civic cx... car started fine but now car would start and idle for a couple minutes and then it just dies.. car wont start after... cranks and everything but wont start.. any ideas?
Old Jan 12, 2009 | 12:04 PM
jr_deleon's Avatar
Default Re: car wont start
Did you perform any diagnostics on it? Fuel pressure, spark, fuel, timing, idle speed?
Old Jan 12, 2009 | 12:05 PM
Former User's Avatar
When it won't start, check for spark and listen for the fuel pump priming. Is the CEL staying ON when the key is turned to ON(II)? What ECU are you using?
Old Jan 12, 2009 | 12:07 PM
lhd dc2's Avatar
So your saying its turning over but not cranking? Have you checked to see if your getting spark? Fuel pump coming on?
Old Jan 12, 2009 | 12:13 PM
civicb16eg's Avatar
fuel pump is priming... and its getting spark.. the car will start occasionally and hold idle for a couple minutes but then shuts off.. then the car wont start nemore.. it gives that weak crank like the battery is dying out.. ive tried using a jump cable and im getting the same results..
Old Jan 12, 2009 | 12:14 PM
civicb16eg's Avatar
No CEL... using a virgin p28
Old Jan 12, 2009 | 12:16 PM
You might want to check whether the timing belt slipped a tooth.
How the cylinder compressions?
Old Jan 16, 2009 | 11:36 AM
civicb16eg's Avatar
the problem was the battery.. thanks to everyone who tried to help out..
JDM Freakk
Jun 21, 2011 05:36 PM
SsB_Db8
Apr 30, 2009 07:29 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
muhaMan
Jul 3, 2007 10:01 PM
nitroacc0rd
Mar 1, 2003 11:08 AM
