1st gen B16 has 2 oxygen sensors....HELP
Old Jan 12, 2009 | 10:36 AM
lsvtec hf's Avatar
Default 1st gen B16 has 2 oxygen sensors....HELP
I have some guestions about the two O2 sensors on the first B16's. I have looked to see what to do with them if I want them hooked up correctly.
Let me get this right. They are both actually primaries. One is for the #1 & #4 cylinder's and the other is for the #2 & #3 cylinder's. Is this right?
The pins are C16 & C8 Correct? (PWO & PR3 ECU's)
OK now I have heard that having them both hooked up correctly, will actually make it run too lean. Now the setup I have is an LSVTEC 11.5-11.7 comp, on GSR cams. Running on an B16 OBD-0 ECU ( probly not the greatest idea)
As of right now there is only one O2 hooked up. I was planning on hooking both up to the correct pins and seeing where the Air/fuel is on a Dyno.
I know this is an old dilema with the majority, but I need to get this taken care of and do it the right way......Even if I skip the OBD-0 crap and go to OBD-1. Im in Ohio, if someone can help me or at least steer me in the right direction it would be very helpful...
Old Jan 12, 2009 | 10:49 AM
Blown90hatcH's Avatar
Default Re: 1st gen B16 has 2 oxygen sensors....HELP
Recipe for disaster man. That setup with that ecu stock. Tune it on BRE or something if you want to stay preOBD. Or get a harness and convert to OBD1. Couple good websites for harnesses and ecus.
www.rywire.com
www.xenecron.com
Old Jan 12, 2009 | 07:38 PM
lsvtec hf's Avatar
www.rywire.com
www.xenecron.com
Is it a total disaster no matter what I do with the O2 sensors cuz, im useing a B16 ECU? Or will it be a disaster if I use both O2's??? Does BRE have a tuning limit cuz, its OBD-0? Please explain BRE. Who can tune useing BRE???? THANKS
atmdc
Dec 28, 2012 07:22 PM
SmogTech01
19
Jun 11, 2007 02:25 AM
EF-Boy91
Sep 16, 2006 07:37 AM
ANGELIQUE
Sep 16, 2005 07:46 AM
spaceman
May 17, 2004 01:34 PM
