OEM 88-91 CRX Si Rear Sway Bar...how to install on an 88 CRX DX
Old Aug 6, 2002 | 12:18 AM
isledude's Avatar
Default OEM 88-91 CRX Si Rear Sway Bar...how to install on an 88 CRX DX
Does anyone know how to install a OEM Rear Sway Bar on an 88 CRX DX? 'Cause when I jacked up the car and I can't find the bolt to mount the bracket? Apparently, I was told that it won't fit on a DX since it can't mount it? Is there anyway I can install this rear sway bar or someone already did the install that can tell me how? Thanks in advance.
Old Aug 6, 2002 | 12:25 AM
ghettocrxsi's Avatar
Default Re: OEM 88-91 CRX Si Rear Sway Bar...how to install on an 88 CRX DX (isledude)
if you are useing an oem si sway bar... there are holes in the rear arms... with a nut welded onto them.... so u need those arms... instead of the ones u have...
Old Aug 6, 2002 | 01:34 AM
wronghand's Avatar
I have an Si rear sway bar on mine. You will have to have a set of Si lower control arms. Yow will also have to make (or have made) some custom brackets for the sway bar. Here is what I did:
Old Aug 10, 2002 | 12:53 PM
isledude's Avatar
Default Re: OEM 88-91 CRX Si Rear Sway Bar...how to install on an 88 CRX DX (wronghand)
Thanks man...that's mean I need to either sold my rear sway or change my low arm control bar.
88crxhfb16
Jul 24, 2006 05:30 PM
Nisif
16
Jan 24, 2006 07:53 PM
Turbo Dan
Oct 24, 2005 02:18 PM
CRexcellence
Dec 2, 2003 05:14 PM
The_PissingDog_Crx
Jun 27, 2003 11:56 AM
