quick questaion
hey guys new to the site, and hopefully will get a ef hatch with a b16a soon.
my question is that, what oil filter do i buy for it?
i did search a bit, but came up with zero answers. thanks
Here are oil filter part numbers for CRX:
Oil Filter
Brand-----Part#
OEM - A6029-OES-A6000 or 15400-P0H-305
STP - S2808
FRAM - PH6811
K&N - HP-1004
MOBIL - M1-104
Oil Filter
Brand-----Part#
STP - S2808
FRAM - PH6811
K&N - HP-1004
MOBIL - M1-104
All Honda OEM filters have the same thread and seal with very few exceptions. Basically anything 88-current, S2k is larger physically, Insight is smaller physically. All of them work. I use S2k filters to get more filtering area.
1g Legend is different, as is one other 'recent' design, but I can't remember what it is.
Here is my rule of thumb: For every day normal use, go with larger oil filter to get more filtering capacity. For racing only purposes, go with smaller oil filter to reduce the heat build up inside the filter which may cause the filtering material to collapse and fail.
dude, it's simple.
look up at your parts store in the oil/air filter book (in the filter section) for 1989 crx sir, which has the b16a motor and go from there. as for mine i got a gsr, which is from the 1996 acura integra gsr.
just look dat up or tell the store guy too help u look it up :D
The oil is the same temperature, no matter what size filter it is.
Please someone prove me wrong, I'm not an oil filter technician though common sense seems to support me.
[quote=4drEF;37096943]I thought you put a smaller filter on a race engine to bump up oil pressure slightly.
quote]
i was thinking the same thing too. plus i thought that the smaller one would expand less when it's hot(or was it the other way around) cause of the size
quote]
If the water doesn't spend enough time in the radiator then it doesn't have time to cool down. If your radiator is too small then the water won't cool down enough by the time it makes it all the way through. also, water flow is regulated by the thermostat. You have low rpm cooling problems when you remove the thermostat - again - because the water doesn't sit in the radiator long enough.
Smaller is WORSE for cooling. You want lots of cold surface area to contact the hot fluid. you know those fake plastic ice cubes? If you put one of those in a galss of water it will be WORSE cooling than in you used 10 of them. 10 provides WAY more cold surface area.
Oil is continuous flow and doesn't have anything like a thermostat. The filter is there... to FILTER. It doesn't provide much cooling at all especially since it's located on the back of the engine and above the exhaust. I don't see much cool air flowing over that thing even if you put heat sinks on it. You would have to add an external oil cooler (looks like a mini radiator) if you needed to cool your oil. You better know what you are doing at that point because there is an optimum range for oil temperature (something like 180~200 degrees) so it can be warmed up to flow well.
EDIT: on some Honda engines you can find a sandwich adapter thing on the oil filter. It hooks up to the water system. This is an oil heater... water heats up faster in cold weather conditions and the water in the sandwich adaptor thing helps heat up the oil.
Simple answer: The oil pump is a positive displacement pump, so RPM determines oil flow.
I see I wrote it wrong.
The sandwich adaptor thing... this #17 thing
is a cooler, but a heater too. It doesn't disapte a ton of heat and can only cool the oil off to engine water temperature level - so it's not a fantastic cooler.
An oil cooler you might find in race applications looks like this -
https://honda-tech.com/forums/performance-45/mfactory-blowout-sale-1659574/
b18cEK
May 4, 2004 06:18 PM
01TypeR680
Sep 8, 2001 08:08 PM
