HELP! Metal grinding when i turn the key
Old Jan 12, 2009 | 04:41 AM
mxjosh's Avatar
Default HELP! Metal grinding when i turn the key
So the other dY wen i went to start my car all i got was the sound of metal grinding....so i left it for a while came bak...it startd right up the second i turnd the key...so i turnd it off and tryd again....went bak to metal on metal
So i push started it it startd and drove fine so i switchd the starter...still soundin like metal on metal...i checkd the teeth on flywheel and they were good
Anyone have any ideas?
Old Jan 12, 2009 | 05:10 AM
marcs1337's Avatar
Default Re: HELP! Metal grinding when i turn the key
ignition switch...possibly starter...the grinding you are hearing is from the starter, but something is engaging the starter to make it grind...either the ign. switch isnt disengaging, or the starter is bad
Old Jan 12, 2009 | 05:24 AM
z6hatchboy's Avatar
its the starter, im pretty sure
Old Jan 12, 2009 | 06:25 AM
mxjosh's Avatar
Its not the starter bcuzz i switched it 3 times jus to be sure with some extras i have and one outta a perfectly fine eg 4 door i have
Could anythiny with the wiring cuzz this bcuzz i moved my fusebox into the cabin and thr ground for the starter is a little taunt and i recently reloomed my entire harness
Old Jan 12, 2009 | 07:21 AM
The_Honda_Guy's Avatar
It's the starter grinding. Are you sure that it's shimmed properly with the teeth in the flywheel? Are you sure it's installed correctly and that you have the correct starter?
Old Jan 12, 2009 | 11:39 AM
mxjosh's Avatar
any certain way to shim it properly with flywheel because the teeth dont push out till starter had power?
im almost posotive i installed all 3 correct, i no all wiring was on and all
and i have a d16 zc vtec i had a starter from a d15 4 door eg that was workin fine for weeks..then i put the starter on that came on the zc....still grinding..then i tryed one from another d15 4 door eg i have....same thing
i just checked starter signal fuse its fine and i checked the ground i mentioned earlier and it is also fine
Old Jan 12, 2009 | 11:50 AM
Shimming them can be tough to do without knowledge of how to do it. Did your original one come with shims at all? You're correct, the armature in the starter doesn't move out until you start cranking the car, so it can be a PITA to shim it correctly. Have you tried a NEW starter yet, not just used ones?
Old Jan 12, 2009 | 12:03 PM
mxjosh's Avatar
what do you mean did the old one come with shims?
and the car was starting fine for weeks after i swapped it then one day it randomly did this so i dont believe it was from improper installation
and no all starters were used but one was from a car i started the other day so i dont think that one is bad
Old Jan 12, 2009 | 12:04 PM
Sometimes the old starter will have shims already on it.
Does it only make the sound when you turn the key then it goes away?
Old Jan 12, 2009 | 12:10 PM
mxjosh's Avatar
what exactly is a shim? lol
and yes just when i turn the key but it does not start....wen i push started it, it didnt make any sounds when it started up or ran
Old Jan 12, 2009 | 12:35 PM
mxjosh's Avatar
help please!
Old Jan 12, 2009 | 01:04 PM
If it only makes the sound when you turn the key and doesn't make the sound when you push start it then it's definitely the starter. I'd go to the parts store and pick up a new starter and give it a try.
You don't know what a shim is? They come in all shapes and sizes. Shims can be wood, plastic, metal, just abouy anything, but on a starter they're metal.
Just pick up a new starter and install it without shims and see if the car starts and the sound goes away.
Old Jan 12, 2009 | 01:40 PM
mxjosh's Avatar
ok im still not getting what a shim is or y the starter that is perfectly from my running 4 door would make that noise
Old Jan 12, 2009 | 01:42 PM
marcs1337's Avatar
shim=spacer
Old Jan 13, 2009 | 12:50 PM
mxjosh's Avatar
ok im still not getting y a perfectly good started would still make that noise when put into my car
Old Jan 13, 2009 | 01:27 PM
94EGKUSH's Avatar
dude! i had this happen to me before.
Try using a battery you know that works.
just do it then come back.
Old Jan 13, 2009 | 11:12 PM
santacruzccs's Avatar
ignition electical problem
Old Jan 14, 2009 | 12:52 AM
blueg6's Avatar
i have a similar problem. this happens to me when the key is turned too far when starting the car, sometimes my ignition will go as if there was a "4." then thats when ill hear the grinding and also my vtec controller doesnt turn on nor does my radio or any of the dash buttons untill it is brought back down to "3."
EDIT: the grinding only occurs when i step on the clutch.
Old Jan 19, 2009 | 05:43 PM
mxjosh's Avatar
ok....battery is fine because it works fine in my 4 door
all the teeth on the flywheel are fine i checked
it deff. could be the ignition because the ignition has been ****ed up since i got the car...i can take the key out with ease when the car is running
i guess ill try the ignition..but could lengthening the wire from the posotive terminal to the fuse box have anything to do to this (keep in mind i lengthened the wire 2 weeks ago and ran fin till now)
and it does it as soon as i barely turn the key to start the car with the clutch down, so its not exactly the same as what you were sayin blueg6...but could be similar
Old Jan 20, 2009 | 03:46 PM
mxjosh's Avatar
so should i just look into getting a whole new ignition switch?
such as this http://www.autozone.com/selectedZip,.../selectZip.htm
EKSedAndy
Mar 17, 2011 03:29 AM
old-sk0ol
May 12, 2010 12:41 AM
speedracer33
11
Jul 11, 2005 08:00 AM
WTB AUTO EK
May 12, 2005 06:46 AM
HXvtec
Nov 6, 2004 02:15 PM
