My turn: Just installed JDM 4-1 + SMSP Carsound Cat
Didn't have time to reset the ecu... friends and I were damn happy to be done... took about 3 hrs... finished at around midnite. Then everyone went home to bed.
After I got home, I got out of the car and noticed this kind of burnt smell? Could it be from the JDM header (I got it used) or the brand new cat?
Should I even bother resetting the ECU? I've heard that it should learn to correct by itself?
From the cat and header...it's suppose to smell liek that ..dont worry....and yes you are suppose to reset the ecu....
nice setup..lets us know how YOU like it...
Smell/smoke should be coming from the oils that were treated on the 4-1 header... could also be the cat too. Wait a day or two... it should go away! I installed my JDM 4-1/carsound cat last week... I'm still loving it!
Can you FEEL the VTEC pull?
My car idled a little high after the install... resetted the ECU and it was fixed.
[Modified by skafia, 1:04 AM 8/6/2002]
now i dont understand why you would need to reset the ECU?? it constantly adjusts for a changing environment. but whatever...godd job!!
I think resetting the ECU just gets it done faster, instead of having to wait for the ECU to adjust itself.
but doesnt the ECU constantly check the operating environment?
Read this: http://www.hondata.com/techclosed.html
I read the Hondata article.
They say that ODBII engines have 2 O2 sensors (One before the cat
and one after).
My R has only one O2 sensor before the cat.
Does that mean that it's a ODB1 engine ?
and one after).
I guess I'll reset the ECU today. Well so far the car feels a bit torquier... but honestly my butt dyno sucks
Actually one more question... how "tight" should the connection be between the header collector and the cat? I didn't compress the 2 springs on the bolt all the way...
So what kind of cat back exhaust are yall running behind the Carsound Cat.
I'm going to get a JDM 4 -1 and a CarSound Cat, but not sure what kind of exhaust to get with it.
I been looking into Apexi WS.
Also.. I know the CAT has to be 2.5 on the end of the Header, but what size is the opening on the other end?
R1020
Aug 22, 2001 06:37 PM
