Information on HX and VX models
Old Jan 11, 2009 | 10:01 PM
4serioferio's Avatar
Default Information on HX and VX models
I feel very noobolicious asking this but.
Can some one tell me a bit about HX and VX models?
I am trying to help out a friend buying a car, but I couldn't tell him anything about the HX or VX.
While were at it if you can, you might as well tell me about each model.
I now know of Si, EX, LX, DX, CX, HX, VX, HF? are there any more?!
Old Jan 11, 2009 | 10:22 PM
The_Honda_Guy's Avatar
Default Re: Information on HX and VX models
Essentially, the HX and VX are like the CRX HF.
The VX was a trim level for the hatch from 92-95. It was designed so that it would get optimal gas mileage using the VTEC-E system. Instead of increasing performance at higher RPM like the standard VTEC, it would increase low RPM efficiency to create a swirl effect in the combustion chamber to increase gas mileage. IIRC it was a pretty basic car and really didn't come with many options.
In 96-00 the VX returned but came as a coupe in HX trim. This vehicle also used the VTEC-E system also. I believe this came with a lot more options though and had most of the options that the EX minus the power sunroof and regular VTEC system. Also it had it's own special wheels to set it apart from all other trim levels.
If you want pure gas mileage, HF, VX, and HX are the trims you want. If you want power, you'll want an EX or Si model. If you want cheap and good on gas, go with the DX or CX. If you want options but not as expensive and 4 doors, go with the LX.
Old Jan 12, 2009 | 12:07 AM
hondafab19's Avatar
bump..for honda guy that explains it!!
Old Jan 12, 2009 | 05:11 AM
Bense's Avatar
There's actually a civic SE that everyone seems to forget about. It's like a 99-00 LX sedan, but it has painted trim. (I think)
VX/HX are the fuel economy versions. They have alloy wheels because they are lighter and more efficient. Many pieces on the VX that are usually cast steel have been replaced with aluminum. Such as the AC and alternator brackets. HX/VX are VTEC-E
VX is 92 hp
HX is 115 hp
Manual Transmissions:
the 92-95 vx has the same transmission as the 92-95 cx, with the long *** 3.25 final
the 96-00 hx has the same transmission as the 96-00 cx hatch, however it uses the same larger transmission case as the 96-00 ex.
Automatic trans:
there was no automatic VX, but the automatic HX trans' is a CVT and is very problematic.
Old Jan 12, 2009 | 05:29 AM
92VXeg's Avatar
92 & 93 VX....no rear speakers
94 & 95 VX....yes rear speakers
just thought i should send that info your way lol
Old Jan 12, 2009 | 07:13 AM
VX is 92 hp
HX is 115 hp
Automatic trans:
Yes, stay away from the CVT in the HX. Not only is a rebuild and replacement transmission for the car incredibly expensive, but CVT during that time was kind of an experimental thing. Now today there's quite a few cars that use it, but back then there were very few.
Thanks for reminding me of that Bense.
Old Jan 12, 2009 | 01:54 PM
Great, thanks so much for all the information guys!
Old Jan 12, 2009 | 02:00 PM
zyntax's Avatar
wow, I didn't even know a production car came with CVT back then. I'd like to drive one just for the heck of it.
Good info for sure.
Old Jan 12, 2009 | 02:28 PM
Yea, it was one of the only back then that was using a CVT transmission. If you've ever driven one, you'd go insane at how boring and stupid it is.
Old Jan 12, 2009 | 02:30 PM
all_conference's Avatar
my 94 vx didn't come with rear speakers..=(
Old Jan 12, 2009 | 02:36 PM
Targa250R's Avatar
be professional
It's actually called a Civic VP (indicating Value Package), not an SE.
It's also based on the Civic DX, not the LX. It added A/C, painted moldings and door handles, remote power locks, an armrest, and a CD player to the DX.
Kind of like an LX without power windows, power mirrors, chrome window trim, a tach, or a CD player.
Old Jan 12, 2009 | 06:57 PM
Bense's Avatar
SE is canadian, VP is US
http://vancouver.en.craigslist.ca/ctd/979186490.html
Old Jan 12, 2009 | 07:40 PM
92VXeg's Avatar
maybe it just came panel ready...my 93 has to have different speaker panels. friends 94 came with the speaker panels
Old Jan 12, 2009 | 07:49 PM
BryanM.'s Avatar
Resident Gearhead
IIRC rear speakers were dealer options.
Old Jan 12, 2009 | 07:51 PM
Targa250R's Avatar
be professional
Bingo.
Old Jan 12, 2009 | 07:55 PM
94EG8's Avatar
Seagull Management
In canada we also got a 5th gen LX SE, it was pretty much the same idea, canadian LXs were equivelent to US DXs. The LX SE added the clock, center console armrest, passenger's vanity mirror, rear speakers and a different stereo, the really odd thing about it is that none of these 5th gen SEs had airbags, its even stated right in the supplementry manual that came with them.
Yes. There are quite a few of those '99 - '00 SEs around too.
You could get rear speakers in any 5th gen hatch, they were a dealer installed option, the were supposed to be standard on '94 - '95 Sis, optional on everything else.
Old Jan 25, 2009 | 06:13 PM
pentsas's Avatar
Does the VX have 2 O2 sensors? if so whats that all about anyone know?
Old Jan 25, 2009 | 06:25 PM
Targa250R's Avatar
be professional
It has a single wideband O2 sensor.
The HX has two O2 sensors: A wideband primary for fuel metering, and a regular heated secondary to monitor catalyst function.
Old Apr 14, 2009 | 10:29 AM
no speaker panels also....=(
Old Apr 14, 2009 | 10:33 AM
baller status's Avatar
While you're at it you might as well bring up the CNG Civic GX started in 1996 I believe.
Old Apr 14, 2009 | 11:02 AM
brutekiller787's Avatar
^^^yes sir. you can see most of the construction workers around here driving the CNG 7th gen civics. i tell them they're retarded cuz the leave them on idling all day. it's honestly no better to leave those idling all day than it is to just drive the normal ones and turn them off when you get there
Old Apr 14, 2009 | 12:21 PM
NOFX's Avatar
H-T White Ops
Technically the US model is called the DX-V by Honda US, but it's also commonly referred to as the VP or SE.
The DX-Vs I've seen seem to have different parts of the trim painted/unpainted.
Here's the '96-'00 US trim difference thread though.
1carnut
Engine Management and Tuning
Oct 22, 2012 11:21 AM
BioXide02
Apr 19, 2005 06:12 PM
Honda-Hooligan
Mar 13, 2004 04:08 PM
