1991 Ef hatch dies when i give it gas???
ok so i just got a 1991 ef hatch, had a blown head gasket we changed that, i drove it home normally when you step on the gas the car goes faster right??? well this one doesnt it like it want to die sometimes makes no sense like i have to find the sweet spot please help me
really thats why you think???? i will try to put it on that notch tommoorw when i get off work but i couldnt get it on when i put it on thats why it not on there
alrite lisen closely this is like 90% of the time this happens you wireing harness to your ecu is probly the wrong one so if the engine has ever been swaped you ganna have to get the rite one. and i dont think its exspensize just a bitch to do. good luck im never wrong but im not always rite . so look into this man
best way to do it is get it tdc and have the up mark in the up direction and the two lines on the cam gear are flush with the head where the valve cover meets the head
yeah try to correct the timing first see if that cures the problem...also when you did the head gasket did you remove the harness from the intake, make sure you got the correct plug on the tps.
i upluged one hose from the IM and thats it other than that i just straight unbolted the whole intake manifold didnt want to unhook every sensor
Good luck.
The reason he is being an "*******" (he isn't being one in my opinion), is because you are asking a question that you already know the answer to. Your timing is off a notch. Your cams are kept in sync with your crankshaft by one thing -- the timing belt. As I'm sure you can imagine, when your valves are not opening at the right times, there will be problems. Take off the belt, set both the crank and cam at TDC and then put the belt back on without moving anything. At this point, use a socket to turn the crank a couple times and then make sure that the cam and crank still reach TDC at the same time. I'm not sure what engine you have but you have to loosen the adjustable idler puller to get some slack to put the belt on properly. If you get your timing set right and still have a problem, then it is time to inquire further. Until then, you are only wasting time.
Good luck.
Good luck.
I had the same problem with my hatch. I thought it was timing belt too but that wasn't it. It turned out to be the fuel filter. It was all clogged up with gunk. So that's another thing to look into... Good luck man!
why are you lining it up with a mark you made?? honda makes marks for to use. if you do not know how a timing belt should be installed corectly, you need to do a search and find out how to do it, before you destroy your engine by setting the timing wrong.
well lets see i set it to tdc using the mark on the crank shaft pully and the up on the cam gear, there was NOT A SINGLE MARK OR DASH ON THE BELT ITS SELF!!!!
There doesn't need to be. Once the crank pulley is lined up, with the cam gear lined up with the head, it doesn't matter how your belt is placed, your engine is at TDC.
If your going to get pissy over people trying to help you, then find it out yourself.
OP, do you have a timing light?
no i dont believe so im not being pissy, i just want my car to run good sorry! but i had my motor at tdc when i slid the belt off i made a mark on it and the cam gear for my reference ok? and when i put it back on it was like three notches away form my mar, so today i slid the belt off and turned the cam gear down to lign up with my mark, now when i put it at tdc with my crank line up the cam gear is not a tdc help me
