OEM Fog light wiring harness
Old Aug 5, 2002 | 11:01 PM
crx(gator)'s Avatar
Default OEM Fog light wiring harness
well honda doesnt sell them for our 88-91, so im wondering can i use a 92+ harness, will it bolt up to the 90-91 fog lights, also can i use the crx switch or do i need to use the 92+ civic switch...
Old Aug 6, 2002 | 05:52 PM
crx(gator)'s Avatar
Default Re: OEM Fog light wiring harness (crxgator)
anyone...
Old Aug 6, 2002 | 09:19 PM
bryant's Avatar
I have seen the Fog light swithc on eBay a couple times. Check there. but as for wirring im not sure.
Old Aug 7, 2002 | 08:29 AM
Doodoo's Avatar
Make your own. Its not hard. The switch you can get from Honda Automotive Parts.
I think there are three wires on the switch, ground, constant power and switched power. You should run a fuse, 15 Amp, on the constant wire that is connected directly to your battery. Good Luck.
Old Aug 7, 2002 | 09:42 AM
crx(gator)'s Avatar
Default Re: OEM Fog light wiring harness (Doodoo)
but doesnt the wiring harness include wires to make the fogs turn off when you hit the high beams, and they turn back on when lows are on...otherwise i believe the are illegal
Old Aug 7, 2002 | 09:57 AM
wronghand's Avatar
My guess is that it would work. You may want to call the dealership and get the two part numbers. Comparing those will tell you a lot.
NovaRex
Apr 20, 2015 02:14 PM
uhhkilleez
Jun 7, 2012 04:29 PM
nacnud_z24
Honda Civic (2001 - 2005)
Jun 17, 2008 05:24 PM
crazi92hb
Jan 16, 2006 05:04 PM
