Missfire in cylinder 4, but number 3 injector bad, with no miss? READ
Old Jan 11, 2009 | 05:23 PM
standbackimapro's Avatar
Default Missfire in cylinder 4, but number 3 injector bad, with no miss? READ
Well the car is 90 integra with a gsr, the car was misfiring, i found it was cylinder 4 causing the miss, i did a compression test, i pulled up the all data, to find the stock spec resistance for the injectors, i check the resistance on the injector, and checked the injector plug with a noid light, i also did a running compression test
compression test good, and the injector and plug are good, so im thinking wtf is causing this?
so i check all the other cylinders,i get to the number 3 cylinder, and the resistance on it is 17 ohms, so im like WTF, why is the number 3 injector deffiently bad, but no missfire on that cylinder, and number 4 injector is fine, and has the missfire?
so i think for a second, i pull up all data on my computer and look at the wiring diagrams, i get to the A-3 Engine cranks but wont start, which has the injector driver circuit on it, and it clicked, cylinders 1-2 fire in pairs as well as 3-4
so i figured, the number 4 injector was using more current than its suppose to, robbing power from number 3 of enough power to keep it open
anyway just figure id post this, just incase this ever happens to anyone else
aznkid4now
Oct 7, 2012 04:44 PM
d16z6EG
Feb 5, 2010 08:27 PM
GEN2 LS
Aug 23, 2009 09:03 AM
213374U
Mar 9, 2009 06:27 PM
InvaderTrax
May 4, 2008 01:57 PM
