steering wheels issue?!
Old Jan 11, 2009 | 04:22 PM
DC5_Angelo's Avatar
Default steering wheels issue?!
well to give a little backround, made a huge mistake and bought a car with a swap (instead of buying a stock crx and doing it myself). Well the problem im having is that when im driving at higher speeds the steering wheel kind of makes a ringing noise and its very annoying, I can help it a little bit when i push on the bottom of the steering wheel. I didnt know if the problem would be if its not straight or is just better off getting a aftermarket wheel
also another problem (electrical). The brake lights dont work and after some diag into it found that its from the battery to the fuse box but dont really want to dig throught the whole thing to find out where its from. Was thinking of doing some ghetto wiring and was thinking of connecting a wire to a live fuse (but one im not really using, like sunroof) and then connecting that to the brake switch, just an idea and would be thankfull if someone could chim in with some comments, thanks
sorry, cars a 1991 crx with a B series swap
Old Jan 12, 2009 | 12:51 PM
DC5_Angelo's Avatar
Default Re: steering wheels issue?!
anybody?
Old Jan 12, 2009 | 03:25 PM
ef89's Avatar
Refering to the wiring better safe than sorry id dig in and find the short or whatever it may be causing your problem, is there any give in the wheel when you turn it maybe one of the 5 are loose.
jdm_j03
Honda Civic (2001 - 2005)
Feb 25, 2008 09:18 PM
fms1day
13
Nov 28, 2006 02:05 AM
1hotintegra
Feb 23, 2003 06:17 PM
