starter issue
Old Jan 11, 2009 | 02:32 PM
k&c customs's Avatar
Default starter issue
ok i have a 91 crx si and it has a b18 swap well the damn starter will not turn over.. i took it to autozone and it tested good so i put it back on and still noting.. i can press the neutral safety switch buttom in and nothing.. all i hear is a click under the dash.... so i splice the neutral safety switch wires together.. the black and the blue one and still nothing... i also tried runnin a hotwire off another battery to the little femal plug in on the starter and all the starter does is click im lost... need help
Old Jan 11, 2009 | 02:40 PM
Clipsed's Avatar
Default Re: starter issue
try hitting it with a hammer, solenoid might be stuck.
Old Jan 11, 2009 | 02:52 PM
yea but starter tested good at autozone...
Old Jan 11, 2009 | 03:32 PM
anybody?
Old Jan 11, 2009 | 06:37 PM
txihondatec's Avatar
yea same setup,i jus have an 89 rex with the same problem.it's sucks jump starting your car at the track,in the snow,with a gurl it blows dude. I bought a reman starter and still has the same problem,only thing i can think of is grounds ttt for the both of us
Old Jan 11, 2009 | 06:58 PM
JustAnotherRex's Avatar
I'd check your grounds, and also maybe the wire from the + battery to the starter directly.
Sounds like it may not be getting enough juice for one reason or another if the starter is good.
Old Jan 11, 2009 | 08:58 PM
i can run a solid 12 volts to the starter synelnoid male plug and still just clicks... it wont even click with the key.. but it will when i get 12 volts to it
Old May 7, 2009 | 11:13 PM
kcoddah77's Avatar
New User
sorry to thread jack. same problem here. been searching. it's late. i'm two weeks into this build and swap.
b18a1 into 88 crx
did the dpfi->mpfi wiring. question is what does that have to do with the starter? I jump the solenoid, and the starter will turn the motor(forever). i don't care that the motor won't start yet(it has spark). all the grounds are there(starter cranks when jumped).
CRAZY PART= when i release the key, the starter clicks(once). all the relays act normal; as if the car was gonna start just like it always did.
Old May 7, 2009 | 11:14 PM
kcoddah77's Avatar
New User
Icon7 Re: starter issue
damn, old thread.
JuneBugDrfter
Jan 8, 2014 11:03 PM
IIXtremeHansen
24
Jun 11, 2007 10:28 AM
go2sleep
May 6, 2007 08:42 PM
Touge Tuning
May 3, 2006 11:14 AM
