proportioning valve
Old Jan 11, 2009 | 02:12 PM
type Gendy's Avatar
Default proportioning valve
I just picked up a DA 4040 valve, so i was told. How can i identify to make sure this is the correct valve?
Also what should i use on all the brake line nuts that go into it? Never seize?
Old Jan 11, 2009 | 02:18 PM
K2e2vin's Avatar
Default Re: proportioning valve
It should say "4040" on it(technically it's not 40/40).
You shouldn't use teflon tape on the fittings but there are adhesives that would work fine.
Old Jan 11, 2009 | 02:31 PM
type Gendy's Avatar
aaah i see it now, thanks i had to wire brush the hell out of it to find it.
so should i just put some never seize on the threads to make my future brighter?
Old Jan 11, 2009 | 02:32 PM
K2e2vin's Avatar
I guess so; I don't see the problem since the sealing comes mainly from the flaring.
Old Jan 11, 2009 | 02:34 PM
type Gendy's Avatar
well just in case i ever take it off again i guess... The brake nuts were basically welded into the stock one
Old Jan 11, 2009 | 03:25 PM
Targa250R's Avatar
be professional
What front and rear calipers are you using?
Old Jan 11, 2009 | 03:39 PM
type Gendy's Avatar
ex front knuckles and da rear
Old Jan 11, 2009 | 03:46 PM
Targa250R's Avatar
be professional
Good. The 4040 is the correct valve for a Nissin 17CL14VN front and 7CLP13S rear caliper combo.
You could try a very small amount of anti seize compound on the fitting threads but it's not really necessary. Just make sure to use a flare nut wrench on the fittings so that you don't strip them.
Old Jan 11, 2009 | 03:53 PM
JapJunkie's Avatar
Yup 4040 right on it. I am needing EX front knuckles, I got DA ones at the moment w/ rex Si rears. The setup is great. Rear Disc FTMW.
Old Jan 11, 2009 | 04:00 PM
type Gendy's Avatar
i've had a problem with rubbing rear tires ever since i did the da rear disc swap (da lcas) I picked up some si's but with a rough measurement it doesnt seem to have sucked the tire in any if at all...
Old Jan 11, 2009 | 04:15 PM
Targa250R's Avatar
be professional
You should not have used any Integra control arms.
If you did, replace them with your original arms. Especially the UCAs and compensator arms.
Old Jan 11, 2009 | 04:20 PM
type Gendy's Avatar
uca and compensators are both stock crx, i just couldnt get my hands on si lcas at the time. but now everything is crx except the actual trailing arm
88crxvtec
Mar 2, 2014 04:34 AM
khallilD
Jul 17, 2008 08:16 AM
SneezinCD5
Jun 2, 2007 02:41 AM
riceball777
Feb 6, 2004 06:05 AM
