90 civic si drivers axle to short problem
I am trying to figure out if anyone has encountered a problem with driver side axles being to short and what they did to fix it. It seems like it is about 1/2 to short. the engine is a d16z6 with a obx lsd diff in case that makes any difference. Passenger side is correct so I do not think things are shifted to pass side. Also the car has cheap rhino front upper adjustable control arms and etd traction bars with caster and camber in spec. any help would be great or if there is a intermediate axle swap from a later transmission that will fit that may work as well. thanks
t3601
Transmission & Drivetrain
Dec 3, 2009 01:53 PM
