What counts a "Warmed Up"?
Old Aug 5, 2002 | 09:52 PM
FMXer's Avatar
Default What counts a "Warmed Up"?
Basicly what counts as having your car "Warmed up"?
Oil temp? colant temp? a combnation of some things?
I have always heard 3-4 min, but would that apply when the car was running and has just been parked for half and hour? what if its 15 deg outside, is 3min enough?
Basicly I am trying to build a little light that comes on when the car is good to
drive, wont be to hard just some simple logic chips and an LED.
Old Aug 5, 2002 | 10:19 PM
raene's Avatar
Default Re: What counts a "Warmed Up"? (FMXer)
The car should be good to drive after you start it
The ECU considers 'warmed up' based on coolant temperature, so it's probably best to get an AutoMeter gauge and see.
Old Aug 5, 2002 | 10:33 PM
frogsr's Avatar
best way to warm up your car is to just drive... but very slow and easy until the car's coolant temp reaches normal operating temp.
Old Aug 5, 2002 | 10:40 PM
CivicEK.PDX's Avatar
ya...noobie...jk
Old Aug 5, 2002 | 11:56 PM
Kamin's Avatar
Default Re: What counts a "Warmed Up"? (CivicEK.PDX)
if its cold out, 1 minuet of idle
if its like 75+ just stay below 3000 rpm's till the needle gets above 1/5th and your fine.
Old Aug 6, 2002 | 12:25 AM
Katman's Avatar
ya...noobie...jk
lol nice avatar
Old Aug 6, 2002 | 12:28 AM
raene's Avatar
Default Re: What counts a "Warmed Up"? (Katman)
Katman, whatever that peanut-butter-jelly thing is in your sig, it's freaky!!
Old Aug 6, 2002 | 02:35 AM
LsTurbo91's Avatar
Basicly I am trying to build a little light that comes on when the car is good to drive, wont be to hard just some simple logic chips and an LED.
When coolant temps reaches a certain degree, maybe 180. I'm sure you can rig something up to the ECT sensor.
Old Aug 6, 2002 | 04:51 AM
StyleTEG's Avatar
Default Re: What counts a "Warmed Up"? (LsTurbo91)
I think you misunderstand his question
He wants to know when the engine is considered warmed up enough where he can push the engine. You should keep the revs down until the engine has warmed up, then once it has you can drive it as you like. He wants to know what considers warmed up enough to drive it as you like.
Old Aug 6, 2002 | 06:25 AM
FMXer's Avatar
Default Re: What counts a "Warmed Up"? (StyleTEG)
Exactly
Check my sig, I'm boosting my motor and once i pull out of my driveway I'm ready to start GOING
Think of it as kind of like a reverse turbo timer, but instead of waiting for the turbo to cool down so its safe I'm waiting for the motor to warm up so i can use some b00st.
Old Aug 6, 2002 | 11:22 AM
jetdriven's Avatar
i wait until i get 1/4 scale deflection out of my temp guage before revving over 3,000 RPM. this would correlate to about 145 degrees. when fully warmed up it is 1/2 scale and 210 degrees.
Old Aug 6, 2002 | 12:28 PM
riceboy's Avatar
Default Re: What counts a "Warmed Up"? (jetdriven)
start it, smoke a cigarette, and when you are done, the engine will be at operating temp by then, thats my theory, but I never put any load whatsoever on the motor until the thermostat has opened.
Old Aug 6, 2002 | 03:03 PM
Chiovnidca's Avatar
Exactly
If you want to "stomp er down" with boost right out of your driveway, I would reccomend you let it warm up until the cooling fans cycle. If you had a race car you would warm it up all the way before racing. Wouldn't you?
Old Aug 6, 2002 | 08:58 PM
LsTurbo91's Avatar
I think I understood his question quite well "When it reaches 180 degrees" and if he wants to wire up a light try it with the ECT sensor.
Old Aug 6, 2002 | 09:40 PM
FMXer's Avatar
180 sounds good, Thanks
Old Aug 6, 2002 | 09:41 PM
StyleTEG's Avatar
Sorry, wasn't responding to you specificly, but the people who post before you with "as soon as you start your car".
Old Aug 6, 2002 | 10:27 PM
JDM nerbie's Avatar
New User
on a honda the normal operating temp is when the fan kicks on for the second time.
Old Aug 7, 2002 | 03:39 AM
88_SC_CRX_Si's Avatar
New User
Default Re: What counts a "Warmed Up"? (nerbieR)
Main thing is letting the oil pressure build-up first, before you drive off...
[Modified by 88_SC_CRX_Si, 4:39 AM 8/7/2002]
Old Aug 7, 2002 | 05:45 AM
Doctor CorteZ's Avatar
Default Re: What counts a "Warmed Up"? (88_SC_CRX_Si)
and letting the oil WARM up
invisible
Dec 1, 2006 12:35 PM
zer0zer0 TypeR
Mar 15, 2004 09:35 PM
Aphrodavid
Feb 1, 2004 03:54 PM
Aphrodavid
Jan 31, 2004 05:50 PM
FMXer
Aug 7, 2002 03:19 PM
