Stock ITR flywheel and clutch in my B18C1 '92 CX hybrid.
I have a friend that is going to sell me his ITR flywheel and clutch DIRT CHEAP! ($200 for both). They both only have like 30k miles on them.
What do you think of this setup? I really wanted to go with a better, aftermarket clutch...but for the $$ I can't really beat this...right??
If your current clutch is dead according to your sig. Sure that will be good enough to get you by until you can get the aftermarket clutch of choice.
The Type R flywheel weighs in at about 15 lbs. I weighed it on a digital scale at U.P.S. I brought in a couple of "B" series flywheels and recorded the results.
Stock "B" series flywheel----about 17 lbs.
Type R---15 lbs
Assco Motorsports aluminum B series flywheel (with steel friction surface) -----about 8 lbs.
Type R---15 lbs
i can bet you that since he upgraded then it means the clutch was on its way out...
I will be installing everything tomorrow morning. Wish me luck!
BTW, is a stock GSR flywheel worth anything??
danny98r
Jun 23, 2004 12:33 PM
SPOON_BeIgHtEeNsEe
Jan 10, 2004 12:39 PM
