FS: T-bone built B18C1 turbo long block
Old Jan 11, 2009 | 09:23 AM
GTibunny16v's Avatar
Default FS: T-bone built B18C1 turbo long block
Removed from "project daily driver". More info on the whole setup here: https://honda-tech.com/zerothread?id=2192088
what you get:
JDM B18c1 block
Machined by Mike Belben to 81.5mm (stock sleeves)
Built by Tbone aka Tom Cote
Arias 81.5mm, 9:1 Thermal coated by Tbone
Manley H-beam LS rods
ACL Bearings
Balanced and micro polished LS crank
New OEM ITR oil pump
Baker Stage 1 p&p cyl head
New CTR cams
AEM adjustable cam gears
Skunk2 complete valve train
Valve cover has 2 -12an fittings welded to it
Coolant transfer pipe and cyl head water neck have -6an fittings welded for turbo coolant lines.
New Honda timing belt and tensioner and water pump all used when built.
Oil pan has a oil return fitting welded to it also.
This is a complete valve cover to oil pan engine.
Car was never acually used a daily driver, more of a garage queen and weekend car. Less than 1-1.5k on the whole setup, fully tuned by Jeff Evans, never even tracked . The car was babied, never ran low on fluids, never over heated etc. Engine had 4 oil changes
in its life. Mobil 1 was used from break in to its last change.
I built this car for my friend and when he decided to part it, I bought it for a drag car which has fallen through. Only asking $2700. Have over $3500 into it.
Old Jan 11, 2009 | 11:18 AM
Default Re: FS: T-bone built B18C1 turbo long block
up
Old Jan 11, 2009 | 02:20 PM
bump
Old Jan 11, 2009 | 02:26 PM
kaptn krunch's Avatar
Good price GL with sale!!
Old Jan 11, 2009 | 05:59 PM
Thanks for the bump
Old Jan 12, 2009 | 03:55 AM
morning bump
Old Jan 12, 2009 | 08:19 PM
up
Old Jan 13, 2009 | 05:42 PM
bump
Old Jan 14, 2009 | 04:10 PM
ttt
Old Jan 15, 2009 | 07:20 PM
bump
Old Jan 17, 2009 | 05:39 AM
ttt
Old Jan 18, 2009 | 06:30 PM
bump
Old Jan 20, 2009 | 01:48 PM
up
Old Jan 20, 2009 | 04:53 PM
JCB's Avatar
JCB
Would you sell just the short block? If so pm me how much.
Old Jan 22, 2009 | 06:15 PM
PM sent
Old Jan 24, 2009 | 06:32 PM
ttt
Old Feb 1, 2009 | 05:20 AM
ttt
EcHoB18C1
Sep 29, 2011 09:34 AM
GTibunny16v
Mar 31, 2009 04:54 PM
GTibunny16v
Northeast (Sales)
15
Jan 24, 2009 06:32 PM
ACrite3404
Mar 25, 2008 03:54 AM
gsrwanted
Jan 28, 2008 09:23 PM
