Not starting
Heating on my accord was very poor and I was told to change the thermostat. After I chabged it, I doesn't start anymore.The lights are coming on but no spark as there is no current coming to the spark.Please help me.
Check all the underhood fuses, maybe something got accidently shorted out??? Do you get power to the thick black wire with yellow stripe wire at the distributor? What year is your car?
Thanks for the replies.
I tried to last night again and after few attempts, it started eventually. I then without stopping drove about 9 miles and left the car off my drice way. When I tried to start this morning, it failed again. Could it be some water went in somewhere?
When you eventually got it started, did it skip for a few moments and then clear out?
P
Yes; it did skip few times before started. It never been in any rainy areas. But, while I was removing the horse to replace the thermostat, the water started to flow from the horse for few seconds and then its stopped.
It sounds like a weak ignition coil to me, a cold engine is harder to start than a warmer engine. It could be other issues but I have seen this before, multiple attempts to start and eventually start. I had test equipment to prove my point though.
P
Thanks for the both replies. I think the problem is more or less like Adam's view. Its prob the moister somewhere causing this trouble. I tried last night after work, after several skips, it started. I moved the closest point to park safely from yellow line. This morning arround 7AM, I started and it did with the first attempt for the first time. I then took my kid to drop him at the coach point which is about 2 miles. After driving about one and a half mile, it started to miss and was making some funny noice near the ignition switch(like a short). It alsmost stopped, but then picked up and drove fine. I didn't stop the engine anywhare until i parked the car at the parking point.
I am goinging to remove the distributer cap and do a bit of clean and see. I will let you the outcome. Or, is there anything else I need to check?
What year is this Accord?
P
There is a Honda Recall (02-031) which discribes the drivability condition for most models starting with the 1997 model year. It involves the Ignition Switch.
Copy of recall text here:
http://www.alancoxautomotive.com/assets/recalls/A02-031.pdf
I remember earlier models being being afflicted with this as well.
It might be something worth considering.
P
Hi Adam, I have now cleaned the carbarator and is working fine. Thank you very much for your advice and the effort. This is a great site I am glad I found it.
Would you be able to help me to rectifiy the heating problem, After changing the thermostat, it hasn't mad any difference. The car is still blowing a very mild warm air.
Thanks
Thanks
Thanks
Thanks
It may be stuck particially opened.
It's mounted to the firewall (engine side) and has the push/pull control cable attached to it. This could also not allow the temp blend door from fully closing in the Heater Case.
If this is indeed what you find, let me know. I'll give up the proceedure to fix this very common Accord Heater problem.
P
AccordInTheMaking
Oct 30, 2007 05:32 AM
b16hatche
Dec 12, 2005 08:50 AM
