HUGGGEEEE GARAGE SALE!! Tons of parts. ALL Has to go!-CHEAP LOOK@
Old Jan 11, 2009 | 01:13 AM
94eg5squadMD's Avatar
Icon5 HUGGGEEEE GARAGE SALE!! Tons of parts. ALL Has to go!-CHEAP LOOK@
Zip: 21222
Contact- CODY - 443 220 7142 CALL/text
Willing to meet or you can pick up
Have plenty of Vouches
All items ARE FOR SALE OR FOR TRADE
looking for- ls vtec parts, eg coupe parts
Nitrous Parts
1. Nitrous Works Purge Solenoid. got it with a nitrous kit i bought. i never used it. it has 2 blue wires.
25$
2. Nitrous 10 lb Bottle. Blue. Cold fusion Nitrous System is the brand. In great Shape. Has a marshall gauge on it. use with any kit.
100$
3. Nitrous Line/Steel Braided lines.
Air Conditioning Systems
2 Sets of : 92-95 civic complete A/C setup. has the r12 to r134 change over kit on both kits. everything included just pulled out of my old DD and my new DD car. comes with all the pieces, wiring, bolts. nuts etc...
100$ a set
SWAP
b18b1 ls swap ( currently in md DD )
-came out of a wrecked 95 acura ls special edition with almost 90k on it.
-motor just had timing belt, waterpump, oil pump and head gasket. full complete service. the motor runs excellent! also has a brand new distributor on it along with new valve cover gasket new tb gasket new exhaust manifold gasket.
-motor is bone stock it has a b20 valve cover on it.and it has a bdl cam seal. also has a gsr tb. car is tuned on s300 and runs great.
-jdm gsr trans w/lsd 50 k tops. trans is butter. fresh axle seals and trans fluid.
-act 6 puck unsprung clutch heavy duty pp. fresh resurfaced flywheel.
-can include a stock header
-can come with a stock ecu.
-wont come with axles but with halfshaft
-will come with stock mounts
----car runs great never had any problems. no knocking or an wierd noises. car starts right away and runs all day long. oil changed every 3k. trans fluid changed every 10k. ask any of my vouches motor is clean and runs great. car made good torque and with the lsd and the short trans the car is quick. can see the motor run but the car just got taken off the road. due to being a project car.
1800$ obo. (taking offers and trades on other setups, price is the way it is because of the trans. and the 500$ worth of service done to it 5k miles ago.)
Engine parts
1.--jdm gsr vtec head--- came with my complete jdm gsr swap i bought last year from ana trade. i put the complete stock swap in my car for about 3 months then pulled it to go boost. now deciding to go lsvtec. i used it for maybe 10k. miles. head is in perfect working condition. it has everything but no intake mani and TB. has fuel rail. the head is complete.
LOOKING to trade for a BUILT bseries head. b16/gsr/type r with valvetrain and maybe work done. i have cash on my end.
this is perfect for someone looking to go back to stock or looking to change there set up.
Price for the head outright is 500$ obo
2.--jdm gsr block-- block is from the swap above. was guna get it sleeved now im just guna do lsvtec. complete block with no pistons or rods. sold them to buy aftermarket ones for boost. block is clean! and has been honed.
LOOKING to trade for complete ls bottomn end. plus cash or if its built for all motor ill throw in cash
this block is in great shape
will sell for right price
3.-- OEM GSR HEADGASKET---
brand new in pack. 50$ or trade for lsvtec parts or ls headgasket
ECU's:
1. Pm6 ecu obd0
30$
2. p05 obd1 sohc
50$
PARTS:
EG/DC Rear lower tie bar. silver
40$
92-95 civic coilovers. they are the slip on sleeves and springs. brand is aerospeed.
40$
Bseries eg back mount. stock but good w/energy suspension black insert
50$
92-95 oem complete airbox set up.
60$
2 sets of 92-95 civic wishbones. front suspension pieces.
30$
92-95 civic jdm fog lites. i have a bunch of peices parts/screws/clips w.e outa like 3 sets if you need any pieces. I NOW HAVE A FULL SET!
best offer $
Bseries Starter. Perfect Shape. Came with my jdm gsr swap. i can give you the #'s off it
40$
Jdm Gsr flywheel. mint. prolly 50k.
75$
2 92-95 civic dx. stock fuel pumps
25$
Jdm Gsr stock oem headbolts.
- came off my jdm gsr swap first time it was takin apart
25$
1 B series 2 dseries clutch cables 88-91 civic
15$ a piece
d16z6 valve cover painted like the japanese flag red/white
25$
obd0 jdm b16a intake manifold no iacv, no throttle cable bracket, no tb, does have obd1 inj., fuel rail and stock fpr.
60$ obo
2 92-95 civic fuse panel cover. 1 no diagram, 1 w/ diagram.
5$
92-95 civic fuse box. exterior under hood. all fuses still there.
30$
3 oem civic gas caps
10$
2 92-95 civic calipers. good shape. one set off a si hatch the other off a dx coupe.
40$
2 92-95 civic hood latchs
10$
2 92-95 civic fuel line. oem. from filter to rail
15$
2 92-95 civic dx master cylinders. complete w. resivior, cap and seal.
20$
2 92-95 civic dseries shift linkage w/ stock shifter and 1 w/ aftermarket blue shifter
40$
D series 2 bolt drivers side motor mount brackets
15$
2 b series intake manifold brackets. 1 ls 1 gsr
15$
NGK blue dseries spark plug wires. i think 7mm.
30$
Gsr stock sparkplug wires. good came on my gsr swap
20$
MSD coil to cap wire. BNIB
10$
2 Sets of brand new oem stock length wheel studs.
bought from honda dealer. (8 count)
20$
88-91 radiator fan. has wiring clip.
30$
92-95 civic hood squirters 2 sets
5$
92-95 civic washer fluid bottle. out of hatchback with 2 squiters on bottle
10$
2 sets of 92-95 civic wiper blade brackets and wipers. both good shape.
20$
-----Interior Parts----
92-95 civic black steering wheel. w/airbag. still on column. good shape. top of the wheel is a lil messed up. (dirtbike effect)
50$
2 shift *****. aftermarket blue and silver one. screw on. and one carbon fiber type r style. it has the allen keys.
Offer$
92-95 civic hatch rear cargo cover. cut for 6x9's.
30$
1 set of 92-95 civic coupe back seats. cloth. mint! one set is out of a ex pictures below
40$
92-95 civic coupe/hatch black front speaker covers.
15$ set
92-95 civic coupe black interior plastics. all panels all the way around. everything but dash and door panels (out of the wrecked car at my house)
Best Offer $
92-95 civic coupe grey rear trunk carpet. l&r upper sides
20$
ECU PINS. have about 100. out of my wrecked car! a must for wiring vtec and all the sensors straight to the ecu.
2$
92-95 civic interior mirror covers. for manual mirrors. black
10$
-----Exterior Parts-----
92-95 civic door parts
----- between everything i got 1 set of glass. they came out of jdm doors. supposed to have a bronzish tint. and i have a extra pass. side glass. IM WILLING TO PART OUT ANY PIECES JUSt LMK WHAT YOU NEED.
92-95 civic black cowl plastic. (bottomn of windsheild) all clips and rubber there. prefect shape.
40$
3 Passenger side jdm amber corner lights. all 3 same side.
10$
92-95 civic front bumper teal in color fits coupe or hatch some scratches and nicks in paint cut for fog lights can come with foglites for an extra 35$
35$
92-95 civic hatch rear glass. has tint on it. not sure what % and a Brian crower sticker.
30$
2 92-95 civic rear bumper supports. 1 coupe 1 hatch
30$
92-95 civic coupe trunk tag/tag lite plastic. flat black comes with lights/bulbs wiring
10$
92-95 civic wiper motor. (under cowl plastic at bottom of windshield
30$
2 92-95 civic gas doors. oem. both teal in color
15$
PICTURES- ( i have dig. camera but i can get pics of anything on my cell phone and then send them to you. So text number at the top for pics )
1 set of the Civic Coupe Back seats:
Teal Eg front bumper:
SOHC vtec VC: ( a lil beat up but still looks ok )
PLEASE PM ME OR REPLY WITH ANY INTEREST OR ?'s
BUMP IF YOU VIEW
Default Re: HUGGGEEEE GARAGE SALE!! Tons of parts. ALL Has to go!-CHEAP LOOK@
bump
Old Jan 11, 2009 | 02:11 AM
buckNasty's Avatar
could u pm me a ballpark figure u want on the rods/pistons? and are the pistons oem or aftermarket?
Old Jan 11, 2009 | 09:52 AM
pmd
Old Jan 13, 2009 | 06:23 PM
bump
Old Jan 18, 2009 | 02:04 AM
trip-doh's Avatar
I live in South Carolina are you willing to ship the long block? Can you send me some pics?
Old Jan 19, 2009 | 11:57 AM
sorry but have alot of local interest and it would be easier
bump
Old Jan 22, 2009 | 11:23 AM
bump
for those who CALLED ALREADY ABOUT THE D16Z6 PLEASE RETURN THE CALL IT IS READY TO GO!
update!!!
Old Jan 23, 2009 | 08:25 PM
bumpage
Old Jan 26, 2009 | 06:24 AM
alot of parts added
Old Jan 26, 2009 | 12:37 PM
SiBuddy00's Avatar
PM sent on P05 and P06
Old Jan 28, 2009 | 08:59 AM
bump all pms replied
Old Feb 3, 2009 | 09:44 AM
update.
rack sold
tailgate sold
swap sold
mount sould
wheel spacers sold
p06 sold
thanks everyone
updates soon
Old Feb 8, 2009 | 06:55 PM
bump
Old Feb 8, 2009 | 07:34 PM
maxim's Avatar
pm'd on A/C system. Also very insterested in the interior mirror covers.
Old Feb 12, 2009 | 11:50 AM
bump
Old Feb 14, 2009 | 06:56 PM
bump update
Old Feb 14, 2009 | 07:37 PM
EFSedan#6's Avatar
Bump for lookin.
Old Feb 17, 2009 | 06:14 AM
bump to the top
everything needs to go! come get it all
Old Feb 17, 2009 | 07:03 AM
92vx-t's Avatar
Tail lights still for sale?
Old Feb 17, 2009 | 07:19 AM
yes for a hatch?-
Old Feb 17, 2009 | 09:27 AM
92vx-t's Avatar
^Yeah, i gave him this link so he might be getting in touch with you.
Old Feb 19, 2009 | 12:53 PM
bump. one black driver side door sold
mirrors sold
tail lights sold
dimmer switch sold
Old Feb 23, 2009 | 06:25 AM
type in BUMP
Old Feb 25, 2009 | 10:17 AM
bump
