ASAP: im hooking up a air fuel gauge
Old Jan 11, 2009 | 12:50 AM
gosu08's Avatar
Default ASAP: im hooking up a air fuel gauge
i need help. im trying to splice the o2 sensor on the ECU. which wire is it or where can i find the diagram to find out?
thanks
Old Jan 11, 2009 | 05:22 AM
GO-FIGHT-KILL's Avatar
Default Re: ASAP: im hooking up a air fuel gauge
thanks
I'd recommend stopping where you are with that.
Just slicing an air:fuel ratio gauge into your stock narrow-band oxygen sensor signal, won't do any good (Other than giving you a cool light to look at). Get a wide-band oxygen sensor setup, that will give you PRECISE readings.
They're not expensive, as a matter of fact, I can sell you an AEM unit for $208.
Old Jan 12, 2009 | 10:31 AM
gosu08's Avatar
yeah i stopped already.
Old Jan 12, 2009 | 11:20 AM
highroller54's Avatar
truth
Old Jan 12, 2009 | 02:26 PM
ZygSpeed's Avatar
The AEM unit is nice and I use one instead of the secondary O2.
Helps with tuning and to make sure things are still OK afterwards.
Old Jan 13, 2009 | 02:01 AM
gosu08's Avatar
i hear the ngk one is really good as well? anyone used or using it?
HAWK4295
10
Mar 6, 2009 12:11 PM
blueintegra
Aug 17, 2007 05:20 PM
brad98prelude
Dec 28, 2005 04:17 PM
mustbenu
Jan 27, 2004 11:21 PM
mntuner2
Aug 4, 2003 12:07 PM
