CAI vs SRI
i did a search and found some answers, but nothing with the 06+ (i have an '07 Si). so, i was wondering if i could get your input between a cold air intake and a short ram intake. is there a significant power difference? i actually read on one of the other posts that the SRI actaully reduced stock power. think that was an older civic though. another concern is hydrolock. i do live in hawaii, so i see quite a bit of rain. i know AEM makes the bypass valve, just not sure how effective it actually is. thanks for any input.
The stock intake system is technically a CAI. It is just more complex. I've read about many adverse side effects with CAIs, one of which has to do with moisture. The filter must be kept in a safe dry space, and near the wheel-well is NOT the right place for it.
If you're going to do this, get an SRI, but re-route the stock air channel (from the driver side bumper) to shoot cold air to your new SRI. You can even build a custom heat shield...like K&N does. I have a Fujita SRI with the stock air channel pointed at it. K&N is probably the most professional way to go, if you care about proper temperatures.
If you are still interested in a CAI, just take the stock air filter out of the filter box, and replaces it with a more aggressive filter (that increases airflow).
To obviously tap into the engine's hidden horsepower, it is recommended to apply an aftermarket Header and Cat Back Exhaust...and so on and so on. It really boils down to, how much money you want to spend or how much you have. G.L.
The main difference between the two intakes is where you gain or lose power. With a SRI the intake piping is much shorter so you have a little better throttle response....but you lose a little power down low . With a CAI the air has to travel through much longer piping so throttle response is worse than that of a SRI. But you gain a little more torque down low as opposed to the SRI.
Another key point to understand is that even though SRIs sit inside the engine bay.....heat soak and power loss isn't an issue because when the car is in motion the engine bay is constantly bringing in cooler fresh air. And since quality SRIs use an open filter element instead of a drop in and closed box (like stock systems)....it allows for more air to be sucked into the intake system. That's why you still gain power even with a SRI.
I still got the stock intake, but i think its time to change the filter (pretty dirty).. I dont really wanna change the whole intake yet,but i need a filter ,, will a k&n filter do me any justice opposed to a stock filter, is there a subniifficant amount of difference??(power wise)?
Road House
However, the Evo X sees gains of about 30hp+ with a K&N drop-in. They must be doing something right.
Road House
No significant power difference between the two.....and depending on the amount of water you suck up the bypass valve may or may not be effective. Nothing is 100% effective.
Road House
do you have numbers to back this up? I used my dash hawk and when the car is idle the intake temp gets up there when car is moving temp is about 15 degrees higher than outside temp. If you drag race with a short ram by the time the temp gets down youre already done with the run. id like to see numbers with a short ram intake with idle temp and driving temps.
How fast were you moving when you read that temperature and what was your idle temperature?
A drag race is one scenario because the car is sitting at idle for a while before launching....so heat soak is an issue. And the race itself is only 10-15 seconds or so (depending on the car obviously). So for that case a CAI would probably be a tad more beneficial...but after 6 seconds our Sis are already at 60mph and that air temperature inside the engine bay is rapidly decreasing..so it could still be considered a "driver's race"....
But if you're already cruising at 50mph on the highway or some side street (like most races happen) and are ready to race someone with a CAI vs. a SRI.....then the temperature difference between the two intake air temps is very minimal and nowhere near enough to be a deciding factor.
Im not just dont wanna put a whole intake system in yet... But i know my air filter is filthy , just dont wanna put a honda one , would rather put a k&n,, i changed to k&n filters for my bike and my girls bike and they actually ride alil better...
I've used K&N drop in air filter.
It was great. I actually got additional 3 MPG ever since I used this filter.
I recently installed CAI.
It sounds aggressive.
It is easier to activiate the VTEC because you accelerate faster.
I wanted the SRI before but thought I can use the CAI and if ever I get tired of it, I can just cut it to make it and SRI. I can always convert it back to CAI by using couplers.
I live in Bakersfield where we get very minimal rain so there is very little worry about hydrolock.
I wash my car myslef. If you bring it to a carwash, the air filter will get soaked because car washes nowadays have underbody water spray.
I believe that's not accurate. If a full $500 + intake system w/ upper intercooler piping is on average only rated for about 28hp or so on the new Evos....how would a drop-in filter produce more power?
For the majority of driving you won't see the difference except maybe in your wallet. The gains (if they are noticeable) will be in a high power environment (ie, track), but they are so small that they can be statistically insignificant if the driver is inconsistent.
Drop-ins generally don't make power. They basically have the restriction of a brand new paper but retain that flow rate consistently instead of the flow rate gradually decreasing as in the case of a paper filter.
DOES THAT SOUND LIKE A SHORT RAM INTAKE TO YOU? Nooooo.
A CAI will suck air from the exact same place your stock system does. An SRI will suck air from inside your Motor Bay.
