Some help please. Benen products info
Old Jan 10, 2009 | 07:58 PM
mitsubishiv5's Avatar
Default Some help please. Benen products info
I want to know how most of the benen products can be fitted to an ef crx.
i was able to fit an eg rear lower tie arm onto my crx by drilling out the mount points. so in theory will i be able to do the same for the front lower? How about pillar pars etc. not much info. and if it was done may i see a picture?
here is my pic for reference:
Rear lower tie bar from an eg. I used the step drill tip and went all the way through to last setting and used washers to bolt down the tie bar to the bar. Otherwise the bolts would have just slipped through the hole. i used a washer smaller than the outer hole but bigger than the driller out mount point.
btw i know there are many products out there other than benen that fit an ef but i like the thickness of the benen products and how they come out with trippy colors.
honda_coupe
10
Nov 29, 2008 09:18 AM
qwrty
Nov 9, 2008 02:39 AM
.Ryan
Mar 19, 2003 02:24 PM
EG3-R
Jul 14, 2002 05:35 PM
Todd00
Mar 6, 2002 12:06 AM
