5th gen vibration
Old Jan 10, 2009 | 07:10 PM
twiztid00002's Avatar
Default 5th gen vibration
whenever my cars warmed up and im just idleing, my car starts to vibrate a lot. when i hit the gas, even just 100rpms, the vibration stops.
just started today
no new mods
any ideas?
also if i turn off things like headlights, defroster, let go of brake, vibration stop for like 2 seconds then start again
Old Jan 10, 2009 | 07:38 PM
93prelude615's Avatar
Default Re: 5th gen vibration
motor mounts?
maybe try cleaning your iacv and TB.
and adjusting you throtelt cable.
Old Jan 11, 2009 | 04:22 AM
Acidcrakker's Avatar
Originally Posted by 93prelude615
maybe try cleaning your iacv and tb.
And adjusting you throtelt cable.
wtf?
Old Jan 11, 2009 | 06:30 PM
Komakazi_830's Avatar
it vibrates at low RPMs and then goes away as you accelerate?
it stops when you mess with electrical stuff because your idle changes with electrical load...so your RPMs go up and vibration goes away until it drops back down...i guess 93prelude615 is saying raise your idle RPM speed?
Old Jan 11, 2009 | 08:04 PM
TheJGB3's Avatar
I have energy suspension polyurethane motor mount inserts, and I have a vibration at idle. The vibration kind of feels like a sewing machine. This vibration is ONLY at idle after reaching operating temp.
Old Jan 12, 2009 | 11:21 AM
yea its the same as this.
but i think it was the cold weather cuz it was freezin yesterday and now its warmer and it stopped.
Old Jan 12, 2009 | 11:59 AM
gstrudler's Avatar
yep, low idle. at a certain rpm range the motor will hit the chassis' resonant frequency and make it shake like crazy. try opening up the idle set screw slightly and it should go away.
Old Jan 13, 2009 | 01:42 AM
TheJGB3's Avatar
Yes sometimes this frequency vibration makes my interior panels rattle and the sunroof sometimes rattles when it's open. Sometimes it drives me nuts..
Old Jan 17, 2009 | 08:03 AM
which screw is the idle screw and which way do i turn it to raise the idle a little?
Old Jan 17, 2009 | 12:21 PM
gstrudler's Avatar
it's the really big-looking screw, top-center of the throttle body facing towards the intake pipe. you should unplug the iacv before setting your base idle with the set screw, and should be around 500rpm iirc w/o the iacv and 750rpm with.
Old Jan 17, 2009 | 08:20 PM
rjr162's Avatar
I hear you about the idle. I had the poly bushings with the balancer shafts disconnected. It was a bit rough at idle, but if the A/C was on at idle.. damn.
Old Feb 17, 2009 | 01:44 PM
while adjusting the idle screw should the car be running or off?
Old Feb 17, 2009 | 02:13 PM
mattsnooz's Avatar
Running. You should read up the steps to setting base idle. Its not as straight forward as dipicted above.
escknx
Honda Civic (2006 - 2015)
May 9, 2014 08:15 AM
1989 Honda Accord
Feb 10, 2007 08:21 PM
'99luder
Apr 28, 2004 10:36 PM
AccPusha
Jun 26, 2002 07:54 AM
