Mid-Atlantic (Sales) VA, DC, and MD
Help needed in Southern Maryland
Old Jan 10, 2009 | 01:06 PM
importheaven's Avatar
Default Help needed in Southern Maryland
I have a 98 civic dx and after an auto to manual swap it does not want to start. Had a short that would cause the fi e/m fuse to pop, fixed that and now it doesn't want to start. It will start to turn over very weakly and then will click and make a buzzard type sound.
Looking for some help pm me or call/text me at 240 925 8907 for more info...
$50 to the first person that gets my car running right!!!
Old Jan 10, 2009 | 04:05 PM
messeduprex's Avatar
Default Re: Help needed in Southern Maryland
it's the battery man
Old Jan 10, 2009 | 06:00 PM
tercel95's Avatar
Agreed sounds like the battery man. BTW represent SOMD!!!
Old Jan 10, 2009 | 11:04 PM
Yeah I got it tested like three times and even when I try to jump it it does the same...
Old Jan 10, 2009 | 11:55 PM
also the radio doesn't work I wonder if there is a correlation between the two
Old Jan 11, 2009 | 05:01 PM
bump wanna get this car running
Old Jan 11, 2009 | 05:58 PM
bigdogadam's Avatar
check your grounds in the engine bay.
Old Jan 11, 2009 | 08:38 PM
there are only like two or three grounds... I even added more in and still no dice
Old Jan 21, 2009 | 07:45 PM
Bump
Old Jan 22, 2009 | 12:58 PM
HybridHatchC1's Avatar
hmm what about the underdash, did you have to change or were you suppose to change any relays, or fuse pinouts? also did the car run before when you had the other problem?
Old Jan 22, 2009 | 01:00 PM
Steven.'s Avatar
have u checked the ACG/IG Fuses and as far as the swap did u switch ecu's and wire up the sensor on the clutch pedal
also check if any wires are shorting/touching hence ur radio is also out now
Old Jan 23, 2009 | 10:15 AM
Yeah the car ran, but ran like **** because I hadn't hooked up the new IACV. As far as under dash I did and always have connected those wires. I fixed the radio, I had popped a underdash fuse for it. I hooked up the starter again after having it tested (fine) and still no go. It sounds like a dead battery when you crank it, however even with an instant boost jumper nothing.
What if I added a big ground between the tranny and the starter? Would that make a difference? I have tested the battery and it worked and the starter and its fine so the problem has to be elsewhere
fredo818
Feb 3, 2013 06:27 PM
ubermoc
Aug 29, 2007 01:32 PM
antiricer
13
Jan 20, 2007 02:52 PM
jdmaek
Feb 23, 2006 06:57 PM
WAT THA!!!
Oct 8, 2004 01:08 PM
