Map Sensor voltage
i took the voltage from the map sensor conector and got the following..
Yellow/Red (+) to Ground - about 5 Volts
Yellow/Red (+) to Green/White- About 5 Volts
White (+) to Green/White- only about .5 Volts
The repair manual says they should all be about 5 Volts....and doesnt say what to do if the readings arnt correct. What do i do? Are these bad readings?
joshd_bh
Apr 18, 2016 12:30 PM
