I think I'm missing some side skirt pieces. 00 SI
I spun out on my way to get my hair cut and went backwards in the ditch. When I did it ripped my side skirt off. I know that there is a front screw that holds it on but that hole was ripped up by the snow. I thought there were also white clips on the frame that the skirt clipped into. There are none on that side at all. I tried looking on Majestic honda for pictures so I could order the clips that I thought were supposed to be there but I couldn't find them.
I'm I mistaken or do they actually have those clips on there?
upon further inspection, I know its supposed to be held on by the clips as well as a couple screws on the front and back. Apparently it was only held on by the front screw and 1 or 2 of the clips on the bottom of the skirt (not the frame ones).
Does anyone know the part number or can I just put it back together the same way?
90331-SD5-003 NUT, SPRING (5MM) $.97
and
90688-SB0-013CLIP B, AIRSCOOP $2.78
and here is the Honda installation instructions
http://www.hondaautomotiveparts.com/.../19813_01.html
sircrxracer
Jan 31, 2004 04:30 AM
