p75 obd1 or p06
Old Jan 10, 2009 | 09:22 AM
eg6boii's Avatar
Default p75 obd1 or p06
i have a question which one will work better and make it run harder. will it be the p75 from the obd1 ls or the po6? need to know in the process of a swap. thank you
Old Jan 10, 2009 | 09:24 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: p75 obd1 or p06
I can't believe you asked that question without saying what type of motor you have
Old Jan 10, 2009 | 09:26 AM
eg6boii's Avatar
it is a 98 b18b.
Old Jan 10, 2009 | 09:30 AM
Deetz's Avatar
Crazy Honda Guy
The P75 is was designed to work with that engine in stock form.
Old Jan 10, 2009 | 09:31 AM
eg6boii's Avatar
so you think it will run better with the p75. just with i/h/e
Old Jan 10, 2009 | 09:43 AM
Deetz's Avatar
Crazy Honda Guy
P06 is from a sohc d series civic, why the hell would you run that over the Integra ecu?
Running an intake, header, exhaust doesn't require changing your ecu man, you'll be lucky to make 10-12hp
Old Jan 10, 2009 | 09:49 AM
IIXtremeHansen's Avatar
lol
b91da
Nov 10, 2009 07:32 AM
axelintegra
Engine Management and Tuning
Aug 29, 2009 11:45 AM
JCracer723
Dec 1, 2003 12:12 PM
BlackThorN
Nov 5, 2003 10:21 AM
