Timing Belt Guides?
when standing next to your driver's side fender facing towards your timing belt, you should be able to read the print on the timing belt without it being upside down. Does this make sense???
I think the OP wants to know which way the guides on the lower cog pulley face.
If this is the case, the washer guides should be flaired out so the opening is wider at the edge. hope this makes sence
DETALZ
Aug 6, 2007 10:53 AM
