Tips for cleaning aluminum welds?!?!
Old Jan 10, 2009 | 08:46 AM
PTPbracket's Avatar
Default Tips for cleaning aluminum welds?!?!
Yesterday I finished my intake manifold for my car and on the under side I have 2 spots where the tungsten touched the puddle. Now the weld there is darker than the rest of the bead. I know its on the bottom and nobody can see it but it will drive me crazy knowing that its there. I really am not a fan of polishing, is there any other way to clean it without scratching it up. I just want the clean aluminum look like the rest of the manifold. I tried acetone but it didn't really do anything.
Any help would be great, Thanks!
Old Jan 10, 2009 | 08:48 AM
punkinbeck's Avatar
Default Re: Tips for cleaning aluminum welds?!?!
pickling paste?? I've used it on stainless, I think they make some form of acid for cleaning aluminum. Nasty **** to work with, does a nice job though
Old Jan 10, 2009 | 09:30 AM
david@didrace.com's Avatar
I use concrete cleaner to clean old aluminum manifolds. Definetly won't make it all shiny but it will make the part a uniform color. I believe it's just Hydrochloric Acid.
Old Jan 10, 2009 | 04:42 PM
srmofo's Avatar
I dunno about cleaning it, But I can tell you the concrete cleaner punkin is talking about is called muriatic acid and its a 30% concentration of HCL. If you use this it would not be a bad idea to give the intake a cleaning with bakingsoda and water to nutralize any acid that might be hanging around after you are finished....dont forget your safety glasses!
Old Jan 11, 2009 | 08:12 PM
PTPbracket's Avatar
awesome thanks guys!
Old Jan 11, 2009 | 09:47 PM
mrbsponge's Avatar
YES!!, as muriatic acid is chemicaly reacted with metal and you do not want to breathe the vapors it puts off so make sure you are outside when you do this. Its best to have a good size container to submerse it in and have something attached to dip it into and pull it out of when youre done
Old Jan 11, 2009 | 10:18 PM
welding's Avatar
muriatic acid wont clean the metal it will eat it away. At least thats what i believe. I would not use it
Old Jan 12, 2009 | 05:05 AM
Unless you know, not believe, try to keep the unfound logic to yourself.
I've yet to have a piece of material vanish after cleaning it with any sort of acid I've used (muriatic, concrete cleaner, etc.). Even sheet metal has stayed intact without any pitting after letting the acid sit for hours.
Old Jan 12, 2009 | 11:28 AM
all_motor_mike's Avatar
mixing aluminum with HCL is fun...................... espeically when its enclosed in a coke bottle for about 15 seconds. lol! about dirty welds though i just carefully buff the spots off.
mike
Old Jan 12, 2009 | 05:01 PM
welding's Avatar
ok well when i throw a peice in to clean it to gave the whole peice a dull finish and looked like it has sat outside for 35 years. It definitely does not looked polished and clean IMO
Old Jan 12, 2009 | 06:09 PM
ROTARY's Avatar
just hit it with a metal brush or a scotch-bright pad/sand paper if you are too **** for that then scrap the manifold.. every time you pop your hood you will remember you dipped the tungsten and contaminated your welds.
Old Jan 12, 2009 | 06:13 PM
That's why I posted - "Definitely won't make it all shiny but it will make the part a uniform color."
H22 CB
Dec 7, 2016 12:57 AM
Xtian8
May 24, 2004 07:18 PM
ijjz
Mar 18, 2004 11:51 AM
evoeone
Oct 7, 2003 09:43 AM
GsR HtCh
Jan 31, 2003 10:44 AM
