type R rods and pistons in gsr?
Old Aug 5, 2002 | 08:02 PM
knighteg's Avatar
Default type R rods and pistons in gsr?
type R owners, i currently spun a bearing on my gsr due to lack of oil! i know i should have checked my oil but like a foolish idiot i didnt! and will have to rip apart the whole engine most likely and am wondering if R pistons and rods would fit in my b18c1 engine(thats if its salvageable) or would some work have to be done to the block and or head? how much gain would i get w/ this set up? i have a friend of mine who is sellin 4 R rods for 150 total and am wondering if this is a good deal(sounds like it!) and will then buy the pistons and rings and just would like some info on this setup and if it can be done, and if so what mods would have to be done to the engine if n e, and how much of a gain i would get in compression hp etc.
thx in advace
tony
Old Aug 5, 2002 | 08:19 PM
dohcsideSi's Avatar
Default Re: type R rods and pistons in gsr? (knighteg)
if you only spun a bearing (or two) your motor is fine, give the crank a polish new bearings and rings and your straight...i wouldn't buy the itr rods not much of a difference...but the usdm itr pistons in your gsr will yield 10.8 compression assuming the head isn't milled...
Old Aug 5, 2002 | 08:53 PM
MikeSarr_GSR's Avatar
Default Re: type R rods and pistons in gsr? (dohcsideSi)
you would see the most power increase on more compression with
a better header and a properly ported head and cam choice
as well...
igorka_91
22
Jul 3, 2009 06:11 PM
Lil_Jon
Mar 4, 2007 06:43 PM
john_racer
Jan 25, 2005 12:27 PM
slodel
Jun 11, 2004 10:20 PM
knighteg
Aug 5, 2002 08:01 PM
